Scratch Build – In Progress Temp name: Black Tower project [Update 16 Sep 2008]
Discussion in 'Project Logs' started by Anobis, 20 Apr 2008.
  1. Anobis
    Anobis What's a Dremel?
    28 Mar 2006
    With scoop, hopper and BI-pod on it weighs 5.9KG. Its heavy But you get joust to it :thumb:
  2. Anobis
    28 Mar 2006
    A small update four now.
    First i totally forgotten to make pic's of the goody's i have gotten a few day's a go.
    The goodies :D
    Their wear 3 hdd coolers but i sold one to a friend be four i made a pic of it :duh:
    Hire you can see the Motherboard with the sound cart.
    An better view of the motherboard.
    Nice sweet motherboard :D
    Back side view of the motherboard.
    few pic's of the sound cart.
    And the work i did until now.
    Made the side panel of the motherboard box.
    Still needs lots of work.
    Hire you can see how its going look inside.
    But be four i can go further. I need to go to the local hardware shop :grr:
    Hope you all like it so far :D
  3. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Friend of mine got that motherboard a couple of weeks ago...it was borked from the get-go. He had to do an RMA on it the same day, after spending over €1500 on a brand new machine! :wallbash:
    Hope your's works well! :)
  4. Anobis
    28 Mar 2006
    I know. So far i understand their wear a bunch made real bad. But the latest batch weir made good. hope it aint broken this one. ore i will send it back :thumb:
  5. The boy 4rm oz
    10 Apr 2008
    That's a real nice mobo. Let us know how those Scythe HDD coolers fair, I am thinking of getting one.
  6. Anobis
    28 Mar 2006
    Thay are real good. My friend had an prob with one hdd Getting way to hot. Even with the 120mm case fan in front of the hdd bracket.
    And with this it cooled down real good to a nice 21C. even in this enormous hot whether.
    I think you can easily take a few more degrees out of it if you put some thermal grease between hdd and the cooler. And make the contact points on the cooler nice shiny bare metal :dremel:
    And btw thy are very cheap and very quiet. Only 14db :thumb:
  7. Anobis
    28 Mar 2006
    A real small update four now.
    Made the holes four power and data wires. And the holes four the water cooling.
    And glued the first parts off the motherboard box.
    Still needs quite a bit of work. But thats four later.
    Hope the glue dries fast so i can go and work further with the motherboard box.
  8. Anobis
    28 Mar 2006
    Small update to day.
    Du to i slip and fell real hard on the concrete flour. I have a real enormous pain in my lower back and right knee.
    All to thank the cleaners. For once a gain to put the doormat on a wet flour. The flour was dry. But under the doormat it was still wet.
    3th time this happen. 1th person fell on his but. 2th teared a part of his arm and 3th me.
    My goodies came in yesterday after only having to w8 little over 30 hours to arrive from the us to my home. I am very amazes :D
    Pitty not more companies send true FedEx :thumb: Well this is what came in.
    Most parts are four a next project.
    And this is the work i did.
    I totally forgotten to make the decal on the left side of the motherboard box :duh:
    stupid me lol :p So i gently taken it off and the glue. Lucky i was planing to make reinforcements after the glue was hard.
    so it had dent had a big surface to stick to.
    So i made a template and cut it out of aluminum.
    still needs work but the ruff idea is there :D
    and hire is it how it looks with the leds.
    Looks nice. But this also needs still some work :dremel:
    Hopefully my back stops hurting soon and i can get to do more soon.
    Hoop you all like the update :D
  9. Anobis
    28 Mar 2006
    Ok a bit of an update today :D
    Glued most parts of the motherboard box.
    And while that was hardening i began to put on some filler.
    And i notice a small wrong calculation...... Again :duh:
    O well. So I made an small pies that fits perfect in the space.
    And while that glue was hardening. I sanded down the side. Wear i put on the filler. And think how i going to do the upper air duct.
    Still needs more filler and sanding but its getting there.
    And hire i made the first pieces of the upper air duct.
    And i got my new paintball marker home :clap:
    my 4th. lol :p
    Short barrel.
    extended barrel.
    its a sweet thing :D But four sum rezone it fires only correctly wen it is low on co2 :eyebrow:
    Need to think this true why and how to fix. Ore els its back to the shop with that thing :grr:
    Well hope you all like the update so far :D
  10. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Excellent work, Anobis! :clap:
    This is shaping up really well, I can't wait to see the next round of pics :thumb:
  11. The boy 4rm oz
    10 Apr 2008
    A new gun and another cool update. Nice work.
  12. Anobis
    28 Mar 2006
    Thanx four the real sweet compliment :D
    Hope to get some update real soon :thumb:
  13. Anobis
    28 Mar 2006
    Thanx but the gun is back to the shop :p
    Don't know fully what wrong with it. But it looks like the grove of the O-ring bolt was to deep.
    And there four the O-ring did dent seal real good. But who knows. I can be wrong :p
    Hope to get some cool updates soon :thumb:
  14. Anobis
    28 Mar 2006
    A small update to day :D
    Made the upper air duct.
    And put some filler on top :D
    And after i sand it down :D
    Still needs more filler and more sanding but its getting there :dremel:
    And got my ram home to :D
    1800Mhz DDR3 Dominator :clap:
    Hope you all like the smaal update four now :D
  15. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Motherboard :thumb: memory :thumb: what's next the job on this mod is nice and waiting to see the next update keep it up man:thumb:
  16. ComputerKing
    8 Sep 2006
    OMG dude
    1800Mhz DDR3 Dominator :D you Smoke!!!!!!!!!!!!!!!!! You rock, you are awesome !
    cool very dam cool And I love your rams :(
  17. The boy 4rm oz
    10 Apr 2008
    Nice job on the top duct. Very nice RAM you have there mate.
  18. Anobis
    28 Mar 2006
    Every one thanx four the real sweet comments :D
    Ive been so busy lately that i barely had time to update this.
  19. Anobis
    28 Mar 2006
    Ok this is what i have don until now.
    Made left side air ducts fins.
    And hire the right one.
    And the tip of my uncle to yous wood glue fore over the mdf filler. Realy works Its a lot more stronger and harder.
    Begone painting the case but hire i kinda regret you zing mdf. It is defnitly not like painting metal. A layer of primer ore 2 and then paint a fuw more layers of paint over it.
    Hell no. Mdf is so dry it sucks the primer in and the paint even wen you think you put on inf layers :wallbash:
    So the paint is looking real horrible :waah: It dries un even. O whel Thursday i got time to go to the local hardware store. so ill get some more paint and do it all over.
    Hope it wil work then better :D
  20. Anobis
    28 Mar 2006
    Ow btw i have gotten my new gun back. But it did not work. so i send it back. the factory had put in a to small spring. Who knew :| So now i got it back and it shoots like a dream :D
    I am so happy that i can cry :')
