Temp of hardware.
Discussion in 'Hardware' started by Mosey, 8 Mar 2006.
  1. Mosey
    Mosey What's a Dremel?
    8 Mar 2006
    I got a new rig recently and i installed in it a temperature guide that tells me temperatures of my case, cpu etc.
    However, im not sure what ideal or optimal temperatures things should be running?
    CPU idle: 35C 95F
    CPU running some pwnage game: 45C 116F
    HDD idle: 30C
    HDD: 35C 95F
    VGA idle: 30C
    VGA: 36C 98F
    Is it time for liquid nitrogen cooling? or are my 80mm fans doing a good job?
    SPECS: 4800x2, 512 Radeon X1900, X-fi, 74gb raptor 10k
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    This is fine... very good, in fact - you shouldn't worry unless it goes above 55 or so.
    Again, nothing to worry about. Hard drives can work reliably up to about 60°C, so you should aim to keep it below 50 or so.
    This part is strange, however... they're too low! Are you using an external temperature probe or software monitoring? You should be able to use ATI Tool (Google for more info) to check the core, vreg and ambient temperatures from your graphics card. I'd expect an X1900 on anything but WC to go over 50°C at least, probably even 80 with stock cooling.
  3. Sherk
    Sherk What's a Dremel?
    10 Jan 2006
    Those are pretty low temps for the GPU, I have an x1800xt that idles about 54C and tops out at 67C or so (playing games for a couple hours, don't know how high it would go if I looped 3dmark). :sigh:
  4. grungedead
    grungedead Minimodder
    8 Dec 2005
    was this temperature guide a software program or a sensor unit that uses pads to attach to your cpu, system, vga???
    try using a program called speedfan, systool or mbm5 but yes your temps are very good
    and i doubt youll be messing with liquid nitrogen cooling but hey knock yourself out just dont forget to keep a worklog on here
  5. Eliminos
    Eliminos What's a Dremel?
    2 May 2005
    Theres no way that your VGA temps are right. I have an X1900 and I wouldn't say that the airflow in my case is bad yet the GPU idles at 55C and loads at about 75.
  6. Mosey
    8 Mar 2006
    Yeah, downloaded a probe for my motherboard to check the temps of the CPU and they came out exactly the same as my temperature gauge. The graphics card temperature was wrong, i had missed placed the temperature input. I checked it out on my cat control centre and it idles at around 48C and loads at around 65. Which allows me some overclocking i believe :).
  7. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    All those temps seem fine, inculding your new graphics card temp, the X1x00 series do run quite hot but are still well within their 125C (IIRC) thershold :)
  8. nukm69
    nukm69 What's a Dremel?
    2 Nov 2005
    are you insane
    liquid nitrogen cooling?.... holy crap - for those times when you dont want your cpu to go above -30c.......
  9. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    Ha, your supposed to overclock it so it stays at about 0c.
  10. Kev_Dawg
    Kev_Dawg What's a Dremel?
    24 Mar 2006
    Hello guys, this is my first post and I am glad to have my first post here, it seems everyone is nice. Well, my X1900 XTX has been at 53 degrees celcius idle for awhile, when the card goes in full load the temperature reaches 83 degreees celcius. I have no idea why and how it goes that high, but I am a bit worried. What is the safe temperature my card can be before I get concerned? If there is any way to improve the temperature of my GPU then please say so, you think adding Arctic Silver 5 on the GPU die would help the temp more, or would it have no effect? :confused:
  11. hitman012
    6 May 2005
    Hello, and welcome to Bit-Tech!
    Those temperatures are nothing to worry about at all; your graphics chip is rated to withstand in excess of 100°C. I would only start to worry if it loads at over 90°C for an extended period of time - not deadly, but it would indicate that something isn't optimal somewhere along the line.
  12. Kev_Dawg
    24 Mar 2006
    Thank you for the response, but can I have the source that you found this information on? I just want proof you know because I spent a lot of money on this card and I do not want heat to destroy it at full load. :wallbash: hehe
  13. Irvine
    Irvine What's a Dremel?
    29 Sep 2004
    Hitman's word is law! :D Your temps are fine...my 9800XT ran at around 87C for over 2 years, and it's still running great. I didn't like it running that high though, so I bought an aftermarket cooler. So, your temps are fine, but if you want to get it cooler, I don't blame you.
  14. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    You can't entirely trust onboard temp readings, sometimes they are just way out - either too high or two low. The acid test is just to run Prime95 and 3Dmark (on full detail) looped for a few hours. If your system is okay then there is nothing to worrry about, if it needs more cooling it will crash and either quit the programs or reboot.
