Temp Probe
Discussion in 'Hardware' started by ICDragon, 3 Aug 2004.
  1. ICDragon
    ICDragon What's a Dremel?
    25 Jul 2004
    how can i find out the tempurature of my computer? can i just buy some cheap 5$ gadget or do i have to pay a bunch of money? i've seen the external bay ones... but I'm getting a SFF and the external bay will be in use, so how can i check temps?
  2. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    MBM (Motherboard monitor) 5.0 should do the trick (Unless your motherboard isn't up to it - but most are these days). You can do the googling :thumb:
  3. kobaj
    kobaj Banned
    4 Jul 2004
    goto doller general get a cheap digital one put the cord in the comp and the lcd outside of the case and it will work fine
