Modding Temp Sensor header on P4P800 Dlx
Discussion in 'Modding' started by desertstalker, 29 Dec 2004.
  1. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    Does anyone know what i would connect to this header to get a temperature reading for the inside of the case?
    It is described in the manual as a "Power Supply thermal connector" and is a 2 pin connector, one pin labeled "TRPWR" and the other is a ground.
    I am asuming some type of thermistor or thermal diode is connected to this but was wonderinf if anyone had any clueas about what as i would like a sensor to measure case ambient.
    Thnaks.
  2. TMM
    TMM Modder
    12 Jan 2004
    Yep, just wire up a 10k thermister. Its wired to the Winbond3 sensor btw
  3. desertstalker
    7 Feb 2004
    So i just connect that across the two pins?
    I suppose you calibrate in software?
  4. TMM
    TMM Modder
    12 Jan 2004
    yes :)
  5. desertstalker
    7 Feb 2004
    Thanks
  6. desertstalker
    7 Feb 2004
    I had a look through the datasheet for the winbond chip and found.
    The thermister i need is a 10k @ 25C and with a B value of 3435.
    The problem with this is there is absolutely nowhere in Australia that has a thermistor with these specs Radio Shack does but that is in the US.
    I found this http://www.users.tpg.com.au/pschamb/a7v.html which explains how to use another thermistor to attain accurate values but it requires the knowlege of the thermistors resistance at 50C which the only thermister i can obtain ( this)
    does not state the resistance at 50C.
    Is there a way to calculate the resistance from the B value?
    thanks
