Electronics temp sensor IC
Discussion in 'Modding' started by RR5, 23 Dec 2003.
  1. RR5
    RR5 What's a Dremel?
    7 Dec 2003
  2. combatkev
    combatkev What's a Dremel?
    24 Dec 2003
    Hi
    I used the TC648 chip that offers the same functions,
    It uses a simpler circuit diagram, so is easier to build.
    The problem was selecting a resistor setting that offered the temperature range I wanted
    The problem is that most temp controllers like to run at full speed at quite a high temperature, I wanted one to be at full speed about 35° to keep the case cool, And off at room temperature. 20°
    I have some details here but I never got round to updating the page with results...
    Try google
    Kev
  3. RR5
    7 Dec 2003
    Thanks, and welcome to the Forums.
    I did try google for that IC name and all I got was the site selling the chip I guess.
  4. combatkev
    24 Dec 2003
    sorry updated the links to the files listed at the bottom of the page.
    Thanks for the welcome, been reading for a while now thought it was about time I registered.
    Kev
  5. Pandalet
    Pandalet What's a Dremel?
    29 Dec 2003
    Oddly enough, Maxim ran a feature on this family of chips recently in their engineering journal (volume 49) - they didn't cover the MAX6656, but they did look at some similar chips.
    This is a pretty funky chip, but if all you're wanting to do is monitor temperature in various places (i.e. you're not using the on-die thermal diodes, and you don't need hardware shutdown), then you might find the Dallas temperature sensor chips handy. One of the more commonly-used ones is the DS1820 .
    Some of the fun features include:
    - One-wire interface, so doesn't need oodles of interface lines
    - Each device has a unique address, which means you can chain a whole bundle of them together on a single data line
    - They come in a plastic TO-92 package, which is small enough to get most places, and can be filed down if it needs to get anywhere else
    - Doesn't need its own power supply - it can parasite off the data line
    Obviously, you would need a little electronic fun to use these directly from, say, a parallel port, but nothing complicated. Interfacing to a micro (I've done this with the Atmel AVRs) is simplicity itself.
    While we're on the subject of Maxim offerings (and no, I don't work for them!), there are also some funky chips for controlling fans. Check out the list
    National also do (or did) a range of temperature-related ICs, if you don't like Maxim or Dallas :)
  6. RR5
    7 Dec 2003
    Welcome to the forums Pandalet.
    I'm trying to see if I can spark anyone's interest to get some and use them, providing us (bit-tech community) with pictures and their experiences using the diodes.
