Other Temperature Reading Software
Discussion in 'Software' started by Guest-23315, 24 Aug 2009.
  1. Guest-23315
    Guest-23315 Guest
    I'm currently using speedfan, but I want something better for taking CPU and GPU temps..
    Any suggestions?
  2. simonw
    simonw What's a Dremel?
    24 Jun 2009
    CoreTemp and GPU-Z.
  3. Lankius Maximus
    Lankius Maximus Minimodder
    21 Aug 2009
    Give HWMonitor a go.
    http://www.cpuid.com/hwmonitor.php
    I have run it in conjunction with coretemp and it gives the same results, however it also provides accurate fan speeds, GPU temps, HD Temps and ambient temps (Case and CPU). I have found this to be the best alround and also the least known about.
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    QFT.
    HW Monitor is the best out there, I use it all the time. :)
