Guide Templates for fan holes
Discussion in 'Modding' started by JoHoschi, 10 Jul 2008.
  1. JoHoschi
    JoHoschi What's that?
    5 Oct 2006
    Greetings fellow modders,
    I was looking for some templates for drilling/cutting holes for fans but didn't find good ones, so I've drawn some :sigh: .
    Please look further down for updateted versions,thanks.
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Good job, can come handy. Thanks
  3. compmodder
    compmodder What's a Dremel?
    23 Dec 2006
    Thanks, will def. come in handy
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    The 80mm/92mm templates will come in very handy indeed... so thanks for those :clap: :thumb:
    I personally just use an old CD/DVD as a template for 120mm fans though :idea:
  5. Nexxo
    23 Oct 2001
    Thanks for that. Always useful. :thumb:
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A purist will have different hole diameters for inlet and outlet positions to match the fan design. A really anal purist will shape and bevel the cut-out to continue the fan venturi profile - it adds several % to air flow and minimises noise. The holes recommended by Panaflo are several mm bigger than yours.
    80mm
    92mm
    120mm
  7. Matticus
    Matticus ...
    23 Feb 2008
    Was your site always called that? I have been on that so many times before, that is where I got my knowledge of how to 5/7volt mod, though I don't remember it being called that.
    But you are right your cut outs are much bigger.
  8. JoHoschi
    5 Oct 2006
    I got my measures from papst. These measurements did work for me but there is always room for improvement.
    cya
    P.S. bye the way: nice website of yours
  9. jhanlon303
    7 Sep 2006
    Anybody got a quick way to scale fron A4 or A3 to something us Colonials use like 8.5 X 11 or 11 X 14 all in inches "naturally" :hehe:
    John
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I've also got some Papst figures for their DC axial fans, the hole diameters are shown as 90mm (80mm fan), 100mm (92mm fan) and 125mm (119mm fan). You're showing 77mm, 88mm and 115mm. :confused:
    If you want, or can only make, a circular hole your smaller sizes are OK, but they will restrict flow.
  11. JoHoschi
    5 Oct 2006
    New version
    So I made a new version with some "minor" :naughty: updates.
    Preview: [​IMG]
    Downloads:
    A4 format (pdf)
    us-letter format (pdf)
    Use the red line for cutting for optimised airflow like cpemma said some posts before.
    I hope this will satisfy everyone :D
  12. ComputerKing
    8 Sep 2006
    THIS ROCKS. I really can't wait to use them.
  13. JoHoschi
    5 Oct 2006
    Yes, that is because I used the diameters of the blades themselfs and not the funnel around them. This was because I needed the cutout in the front of a case and there a optimised hole would look somewhat ugly :cooldude: .
    But as you can see I have improved the design and now both cuts are possible.
    Now if somebody wants to chamfer the cut-outs then the airflow would further improve, turbulences would be lessened and the noise level should drop (in the best scenario).:rock:
  14. jhanlon303
    7 Sep 2006
    Thanks for the US version too!
    John
