Scratch Build – In Progress Temporary name: Bloo Balls --6-29-'11 Bloo 2.0 refit COMPLETED page 47
Discussion in 'Project Logs' started by Cheapskate, 3 Jun 2007.
  1. Cheapskate
    13 May 2007
    Thanks!:D
    @Bulldogjeff - I don't think 5 1/4 would be much to brag about either.:hehe:
    @Remmes - It's the plexi glue. I can understand the clouding in this situation, but the crazing only happens to this one batch of 1/8 clear. I re-did it today and still got a lot of crazing, but it's sealed.:thumb:
    @Gnu - I have not used it yet. I have to set up in the garage to do it, and there's a 104F heat index this week.
  2. bulldogjeff
    2 Mar 2010
    At least 5,1/4 would be a HARD drive not a floppy...This is just going to degenerate now isn't it...lol I'll leave it at that:D
  3. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    If you take it out on the streets would it be a FLASH drive?? :naughty:
    This was around way before i joined BT so glad its been bumped but shame about the amount of work needed. As always looking awesome though :thumb:
  4. Cheapskate
    13 May 2007
    Most of the work is worth it.
    -'cept the stuff I forget to flip before cutting. I was polishing away at the pump when I noticed it was backwards.:duh: I'm getting slow in the head. Part of the radiator cover needed to be re-cut too.
    -I knocked a new top core out.
    -I chopped out an army of clamp parts too.
    -The most WTF res ever is all glued. I'm sanding the outside now.
    -The nice thing about this setup is that it's self-leak testing. I filled it with water and sealed it with the expansion bottle squished. It didn't un-squish overnight, so it's watertight.
    Crazy stuff brought to you by DangerDen.
  5. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    I don't know if that res is full of win or full of madness but it is impressive.
  6. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    MADNESS!!!:lol:
  7. stonedsurd
    11 Mar 2009
    SPARTA!
  8. The boy 4rm oz
    10 Apr 2008
    PATRICK!
  9. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    You're definately not afraid of using colours, eh?
    Yeah, I did it - I subbed. You happy now?
  10. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    It's looking like a crazy chemistry lab.
    I'm looking forward for updates here and on GG.
  11. Cheapskate
    13 May 2007
    Thanks, everyone.:D
    @Nutman - I am on both counts.
    @Fabou - How about a res made to fit a cluttered case? -Naw, I just wanted it to be obnoxious.:D
  12. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Judging on all the colors in this fantastic mod, I say Cheaps must be high when he's working on it:)
  13. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Lol but still a damn good job though
  14. Cheapskate
    13 May 2007
    :lol: Is that another bong joke?
    OK, last time I had a pile of clamp parts to put together...
    -I used some of the ethylene binder I bought to make some bushings for that. These little washers go between the moving plexi parts.
    -Then I riveted them together.
    -I finished the pump up. I made a new bracket and already have it installed.
    -I had to move everything to the garage for my first attempt at copper milling. 'scuse the mess...
    -First I cut out the AM3 base with lots of oil. The edges look bad. I need to figure out the right speed yet.
    -Then I had to figure out how to use this saw attachment by winging it. I had it bind a lot until I figured out the best way to plunge the blade was to hold down the .001 increment key and ease it in manually.
    -Finished the first one. You can see burrs on some of the first slots I cut. There was lots of crashing involved.
    -Here's both bases slightly sanded. The tilt on the grooves on the AM3 base were because my vise doesn't hold material perfectly vertical.
    -Both together weigh in at 1 1/2 pounds.
    -This is after I drilled and tapped the mounting holes. I've found I can tap even 4-40 holes now that I got rid of my cruddy Chinese tap set.
    -Here's a mockup of all the block parts together. The lighter is to give you an idea of how huge it will be finished.:D
    -I gave both plates a rough polishing and lacquered them. The GPU block is ready.
    So I have only a few things left:
    -stealth panel for the base
    -fan shroud on top
    -copper pipe mount
    -finish up the AM3 block
    -re wire the usb port
    -re wire the power switch
    I get to thank Danger Den again for supplying me with the pump and tubing used in this post.
  15. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Damn! The block looks outstanding! Great job man!
  16. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    That res looks like a BONG!
  17. The boy 4rm oz
    10 Apr 2008
    Beautiful work on the blocks Cheaps.
  18. exitus
    exitus What's a Dremel?
    25 Apr 2007
    maybe it is :D
    very nice work, can't wait to see the final result when it's all put together!
  19. Attila
    Attila still thinking....
    22 Feb 2008
    Great work cheaps, I'm watching very closely and soaking up all your
    expertise.:D The blocks look great! :thumb:
  20. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Very nice work as usual. That block looks sick. You have a lot of patience to cut and polish all of those complex little pieces that you get into with your builds.
