Case Mod - In Progress ⭐ "TENEBRIS" a Define R6 build from the darkside
Discussion in 'Project Logs' started by CustomRigs, 23 Nov 2018.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Hello everyone. I wanna start my new worklog here :)
    TENEBRIS
    TENEBRIS means "The dark" or "the darkness"
    The whole build gets a mix from matt black and some darkred (RAL3007) details. The liquid gets darkred(close to black) and alos i use black fittings ! The design consists of different lasered acrylic panels. On the PSU shroud i will place a nice distribution plate as well. In this build i will also do a nice cablemangement on the backside of the mainboardtray with a full sleeved psu cable set.
    Before i start her i have to say "Thanky You" to my supporters in this build. Fractal Design ! EK Waterblocks ! Team Group ! Liquid Cool !
    These are shematic renderings that you can imagine how it is looking later
    Hardware
    Asus Maximus X Formula
    Intel I7 8700k @5,2GHz
    Nvidia RTX 2080 Founders Edition
    16GB TeamGroup T-Force Delta RGB 3000MHz
    Samsung M.2 960 EVO 500GB
    TeamGroup T-Force Delta RGB SSD 240GB
    Seasonic Focus Plus Gold 650FX
    Watercoolingparts
    EK WB VELOCITY CPU COOLER
    EK WB VECTOR GPU COOLER
    EK WB 420 SE and 360 SE Radiators
    EK WB VADAR 120 and 140mm fans
    EK WB D5 Pump and acrylic Pumptop
    EK WB RES X3
    EK WB 16mm HT Fittings
    16mm Acrylic Hardtubes
    Acrylic parts arrived 07.11.2018
    Unboxing of the EK WB package :D
  2. CustomRigs
    8 Dec 2017
    Pictures of the EK Velocity and Vector
    Unboxing Video of the EK Velocity and Vector
    The assembled shroud
    placed acrylic panels
    rendered the backside of the mainboardtray with 3d printed combs
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Did i just look @ 10 shots of the exact same ek water block from the front.
  4. CustomRigs
    8 Dec 2017
    it looks like :D yes :D
    i delete some ;)
  5. CustomRigs
    8 Dec 2017
    Today i installed the EK WB Vector waterblock :)
    Tomorrow i will paint the acrylpanels
  6. CustomRigs
    8 Dec 2017
    Install the EK Vector on a RTX 2080
    also printed the first screwable comb today :)
    quality and finish is good
    printed with PLA and 0.1 layerheight
  7. CustomRigs
    8 Dec 2017
  8. CustomRigs
    8 Dec 2017
    Distriplate is finished :)
    also you can see a schematic pipe running drawing
    Bottomplate with DDC mount and a thread for the drainport which im connecting with a tube extension
    naked :D
  9. CustomRigs
    8 Dec 2017
    Happy new Year everyone :)
    Lets go on with the TENEBRIS Build
    Today i designed my Custom RES for the TENEBRIS project ! All STEP CAD files of the Distribution plate and Reservoir are transfered to Stealkey Customs.
    My Custom RES gets also a acryl cover. Its made of 10mm Acryl PMMA panels with 5mm deep pockets in the bottom and top panel.
    The RES gets connected with a 16mm Hardtube to the distriplate. The fillport is on the backside. Cant wait to hold all cnc and lasered parts in my hands !
  10. CustomRigs
    8 Dec 2017
    still waiting to my distri and agb :/ distri is send but stucks at DHL :/
    i painted the acrylic panels. The panels gets mounted with little magnets. So you can easy replace them for maintenance work :)
  11. CustomRigs
    8 Dec 2017
    Distriplate arrived :D comes out nicely !!
    Tomorrow i start with the tubing and do some preps for the mounting of my custom RES. Hope the RES arrives early next week !
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    holy moly!
    really dig the panels, the patterns and lazer work is very nice
    CustomRigs likes this.
  13. CustomRigs
    8 Dec 2017
    today ive mounted the drainport and bend the first tubes :)
    Still waiting to the reservoir :)
  14. CustomRigs
    8 Dec 2017
    the reservoir arrived and i mounted it today :)
    Tomorrow i will do the last hardtubes and next week i go on with the cables ;)
  15. kim
    kim hardware addict
    10 Jan 2016
    Really beautiful, dark and beautiful, love the design :thumb:
  16. CustomRigs
    8 Dec 2017
    thank you alot ! hope to get the dark theme nicely on my final pictures ! i think i can finish it the next week :)
    The cables get special to ;) i think i post some pictures on monday or thursday :)
  17. CustomRigs
    8 Dec 2017
    Okay the backplate is ready for painting ... what you think ? Cablemanagement is okay ? [​IMG];) The Fillport is accesable from behind with the backplate on. Tomorrow i paint the backplate. The Delta RG SSD goes in the left upper corner. i also mounted the iO cover details on the top.
  18. CustomRigs
    8 Dec 2017
    Finale pictures :) i hope you like tem :)
  19. CustomRigs
    8 Dec 2017
  20. EKJake
    EKJake EK Forum Rep
    23 Oct 2018
    Absolutely gorgeous work on this, man <3 :D
