Other Terrible 3DMark 11 results - Is this normal?
Discussion in 'Hardware' started by dead beat, 2 Feb 2011.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    When running 3DMark 11 @ 2560 x 1600 and in performance mode I'm getting around 16 FPS across all the benchmarks, occasionally popping up to 24 FPS. Is this normal for a system with my specs?
    I ran the Arma 2 benchmark yesterday with all settings maxed and averaged 45 FPS.
    My computer absolutely punishes Vantage!
    I don't understand.
  2. GeorgeStorm
    16 Dec 2008
    Well, it's new, if computers could already get decent framerates (not why people run it anyway) already, then it would already start becoming obsolete.
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    3d mark, is well known for pushing the system to it's limits, what was the score, can you post your link?
  4. dead beat
    15 Feb 2009
    Ok just ran the test again and @ 2560 x 1600 (performance level) the results were as follows:
    - Graphics score.....4117
    - Physics score.....9691
    - Combined score.....5038
  5. philheckler
    philheckler Used to be a pc enthusiast
    23 Apr 2009
    Sli running ? i'm asking because sli didn't work with 3dmark 11 until the latest whql driver 266.58 i think....
  6. RichCreedy
    24 Apr 2009
    thats not bad actually
    but for comparable results you should run the tests at default levels
    my results on default performance settings
  7. Deders
    Deders Modder
    14 Nov 2010
    It's usually pretty standard that no current hardware will run the newest 3Dmark at desirable framerates when it first comes out, especially at very high resolutions like yours.
  8. philheckler
    23 Apr 2009
    For comparison here's what get with my 2 470's at stock 'p' settings - two 580's should be at least 20 - 30 % better i'd say.
    http://3dmark.com/3dm11/525537
  9. Jipa
    5 Feb 2004
    The whole point of a new 3dmark is to be hard as heck on the hardware.
    Also the whole point of 3dmark is to run it at the stock settings so you could compare your results with everyone else in the world. Now, you aren't going to get identical results as other people with similar hardware, but you sure know if the results are in the same league or if there's something wrong with your setup.
    The ORB is there for a reason.
  10. dead beat
    15 Feb 2009
    Ah I see. Also for some reason when I try to upload my scores in Vantage and 11, it just gives me zero. I just ran Vantage again @ 2560 x 1600 (performance) and check this out....
  11. Jipa
    5 Feb 2004
    Also you need to turn PhysX off.
    What versions of the Vantage and 3dmark11 you're using? I don't really know, but I think there are limitations on the free versions (can only run five times or something?), could that 0-result be related?
  12. dead beat
    15 Feb 2009
    So what you're saying is I should just click "Entry", "Performance" or "Extreme" before running the benchmarks and leave all the other settings alone?
  13. Deders
    Deders Modder
    14 Nov 2010
    Why do you need to turn Physx off?
  14. dead beat
    15 Feb 2009
    They're both full paid for versions. I never used to get a score of zero when I had my AMD system.
  15. Deders
    Deders Modder
    14 Nov 2010
    yeah, otherwise it's not a comparable score
  16. dead beat
    15 Feb 2009
    I think it artificially ups your cpu score.
  17. dead beat
    15 Feb 2009
    Maybe that's why I'm getting the zero then.
  18. philheckler
    23 Apr 2009
    The zero score happened to me when i ran the benchmark windowed...
  19. Deders
    Deders Modder
    14 Nov 2010
    I guess if you want to compare CPU scores apples for apples then yeah turn it off, on the other hand if you want to compare physx scores then leave it on.
  20. Jipa
    5 Feb 2004
    It's the same thing with PhysX and the presets. To keep the scores (even remotely) comparable, you just run the presets with PhysX disabled. That's the way everyone does it.
    Ofcourse you may just as well change every single setting, but asking if the results are "ok" with those settings just isn't going to get you anywhere.
