Hello guys, Following up on my previous thread where I had issues with random no-bootups. http://forums.bit-tech.net/showthread.php?t=212046 I got the build working again. But had not tested the sound. So I went ahead and purchased 15£ "iLUV" USB powered speakers from argos. The problem is the large amount of EMI noise coming from the speakers! I hear every click from the HDD..Amplified 10x. I can even hear a constant drone like the spinning of the CPU fan..that too Amplified And its not dependent on the volume of the speakers. The mobo is an MSI p67 rev 3. Fiddling with the line out jack isnt helping either. Do you guys think a speaker powered externally rather than USB would be better?
I think the issue lies with the motherboard. USB powered speakers aren't helping, but Motherboard Audio, even now, is still nothing compared to a dedicated card. There'll always be noise, pops and crackles out of Motherboard chipsets, simply because it has to populate the same PCB, the same ground lines and the same voltage lines as all of the other components. If you really want to eliminate the noise: Pick up a cheap-ish soundcard, The cheaper Xonar series seem to perform well.
