Case Mod - In Progress Test bench mod by Ace_finland [completed]
Discussion in 'Project Logs' started by Ace_finland, 10 Oct 2012.
  1. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    Hey guys,
    So i entered the Cooler master mod competition this year and thought i would start a case mod log here.
    I was thinking for ages for a case to pick and by accident i found the test bench by Cooler Master at a local computer store. I new instantly that this is the case i wanted to modify. It's different enough to other cases and i didn't find anyone else in the competition using the same case.
    After countless hrs designing i think i came up with something worthwhile doing. I was gonna post earlier but after reading the rules i didn't start this thread before fabricating something. Not much to show but at least i have started :)
    So this is the design I'm gonna stick with for now unless i change my mind for a 100th time :D
    Its not the latest version but rendering takes too long so this will have to do. It won't be as glossy as the picture and if i have time I will make some custom gpu back plates and do something to the new Dominator platinum memory i have just gotten.
    Also started fabricating the radiator boxes today.
    Started with some kinda straight pieces of 1mm metal sheet. Decided on 1mm thickness to add some stability and still easy to fabricate
    The machine
    Bent a small test piece to figure out the radius and the measurement, also to get all the angles right.
    Made four pieces so i can mess up two, easier to make extra now than going back to make two new ones :)
    Quick test fit to see how its gonna look
    Also the parts that arrived :)
    Hope you like it and please comment, more comming soon!
    Final shots!
    Sponsored by:
    Livio likes this.
  2. whyte
    whyte What's a Dremel?
    27 Mar 2012
    whoa.. got my attention. subbed.
  3. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    subbed too.
  4. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Nice start :thumb: bending brake and render are awesome. Gotta get a bending brake one day. :dremel: subd
  5. Ace_finland
    11 Aug 2012
    Thanks guys!
  6. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Looking good man, keep my eye on this! :)
  7. Ace_finland
    11 Aug 2012
    Thanks Phame!
    Back after a lot of hrs in the garage and at the workshop at work. Not much of an update when it's full of fail but thought i would share anyways.
    Plan A
    Cut a template of the size i wanted
    Mark the piece to be cut
    Working with my best friend :) (angle grinder)
    After a lot of filing.
    After this i realised cutting the next 3 slots in the metal will make it very thin and will flex and bend a lot. And the plan is to powder coat it after i'm done with it so i can't use any filler. so over to...
    Plan B
    Decided to get all the cuts before bending. Don't mind the tolerances, just forgot to adjust the digits
    Make a "table" for the mill at work.
    Used doubble sided sticky tape between the table and the metal sheets to prevent the pieces to vibrate during milling.
    Fastened the sheets with screws in as many places as possible, i did not want the sheet to move during milling.
    Let the milling begin. Still a Manual mill so need to be very focused :)
    More fasteners used as it progressed.
    Almost done, still need to deburr all the edges and as you can see in the red circle i made a bit of a mess. I had just finished that slot and turned the mill off without turning off the feed. So when i turned the mill on it went like a bat out of.... :( Words can not describe the feeling when that happened. I had spent 6 hrs milling just to do a simple mistake. Anyways, gonna weld it back and see if i can file it down. Wouldn't be a problem if i could use filler.
    More updates coming tuesday-wednesday if i get the metal bent into shape.
    Ace_finland
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking good so far :)
  9. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    interesting project here! main concern with CM benchtable (from reviews) was PCI-E card fixation (lack of it :) ) - interesting to see how it turns out! (and grab couple ideas to mod own bench table :D )
  10. Ace_finland
    11 Aug 2012
    Thanks!
    i've been thinking how to solve the pci-e fixation, what i would like is something that can easily be deteached or something you can just clip onto the card cause it really needs support
  11. Vetalar
    21 Jun 2011
    in my own bench i've take 2 150mm m4 threaded rods near pci1 and pci7 and place 5mm thick PVC strip between 'em. and use self-tapping screws for card fixation...
    like this, but right rod near audio connectors on MB
    Ace_finland likes this.
  12. bulldogjeff
    2 Mar 2010
    Oh yeah, I really like the look of this one:thumb:
  13. Ace_finland
    11 Aug 2012
    Thanks for the idea, i was thinking something similar, it's just very hard to figure out something that goes with the design :)
    Thanks :thumb:
  14. Ace_finland
    11 Aug 2012
    welded and grinded down the mess i did the other day :)
    Got the sheets bent today but now i don't know if i should go with the circular mesh or the hexx mesh. The hexx mesh is made out of 1mm aluminum and the circular mesh is made out of steel sheet which would make the whole construction a lot more stable. What do you think?
    Circular or hexx???
    Thanks for dropping in!
  15. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I would have gone for the mesh :), looks so much better and goes with the geometric designs of the case :)
  16. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    Circular. tuo hunajakenno kuvio näyttää vaa nii pieneltä ja liian hennolta, ja sulla on kuitenkin sen verta pyöreitä reunoja ja muuta nii ton iha rei-itetyn pitäis näyttää aika siistiltä siinä.
  17. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I'd go with the circular mesh, the thickness of the material between the holes is larger than the hex mesh which matches the case better. The hex mesh just looks too thin.
    Only my opinion though.
  18. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    WOW. :jawdrop: i love the render and work done so far. circular mesh Cheesecake i think too and subbed. just epic :thumb:
    Rip
  19. Williz
    Williz Minimodder
    9 Mar 2012
    Circular mesh! I'm eagerly awaiting more updates :)
  20. Ripitup121
    18 Aug 2010
    Is that Gangnam Style or just Finnish?
