Case Mod - In Progress Test bench mod by Ace_finland [completed]
Discussion in 'Project Logs' started by Ace_finland, 10 Oct 2012.
  1. Evenge
    Evenge Minimodder
    16 Sep 2006
    Great work! :thumb: May I ask where did you buy that hex mesh from? I've tried to find some Fin suppliers for it but so far no luck. :(
  2. ZWong
    ZWong What's a Dremel?
    28 Oct 2012
    Sweet! The sketchup looks really great - good luck on the contest.
  3. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice work so far, looking forward to seeing more. Subbed
  4. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    I got it from here here , shipping is a bit much but i had a bunch of stuff i needed anyways :) How much do you need of it? I found a place in Finland you could order some but the minimum size was 2x1m :D
    Thanks!
    Evenge likes this.
  5. Evenge
    Evenge Minimodder
    16 Sep 2006
    Well not sure how much but I believe I could find use to it. :p
    I'll PM you later when I find some time to work on my project once again. My workshop is located about 450km away from me so no fun at the moment. :grr:
    But thanks for the information! :)
  6. Ace_finland
    11 Aug 2012
    Big update coming tomorrow if i get time to take pictures of all the stuff :)
    Sneak preview
    stay tuned
  7. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    2x Lamptron fan controllers?
  8. Ace_finland
    11 Aug 2012
    Oh yes :)
  9. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Nice work and progress I like the use of rivnuts give a nice neat finish :thumb:
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Very very very nice!!
  11. Ace_finland
    11 Aug 2012
    Thanks, its a lot easier than welding, and if you make a mistake just drill it out and redo it :)
    Thanks!
  12. Ace_finland
    11 Aug 2012
    further progress :)
    back as promised :)
    Almost forgot to update, have another project that I've been working on for the last 5 months. Can anyone guess what it is? Just got the "table back from a workshop that leveled it for me. So now i just need to get it assembled and it should be good to go if I just can figure out how to use it :D
    Back on topic
    Started sanding the edges, tried a lot of different machines and files before getting the result i wanted. Still need to straighten up the edges but wanted to mill the fan controllers first in case i make a mistake and need to redo it. [​IMG]
    Milled away a bit of material to get the psu as close as possible to the back of the case to make as much room as possible inside the case
    Started disassembling the new lamptron's
    Very easy to take apart
    In the preview yday you saw the milling so no need to post more pics of that, the controller fitted!
    Had to power it up :)
    After looking for leds for the acrylic and realizing buying "computer leds" are way too expensive i started looking for other options. Found this through a company in Finland. I don't know the price but it should be less than 50€ for 5m of leds. These are 15,6W/m so should be plenty of lumens :)
    The Leds can be cut every three leds and cables can be soldered on straight on the copper tabs, 8mm wide and 2,5mm high. The best thing with them is if you have a 2cm led strip or a 5m led strip all you need is 12V.
    Also have milled the front acrylic, milled a 3mm gap to place the leds in, a nice tight fit.
    From the top
    Full 12V, probably need to run them on 8V, otherwise with 2m's of leds it will look like a nuclear power plant :D
    As low as it goes.
    Still need to sand the acrylic edges to make it more smooth and spread the light even better, but it's a good start.
    Does anyone have a suggestion how to get good photos when photoing the acrylic? They are super red but turns kinda orange in the pictures
    Think that's it for now
  13. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    linear motion bearing blocks and rails... looks like a nema 23 motor mount hole... and oodles of aluminum...
    lemme guess.... um... cnc router?
  14. ZWong
    28 Oct 2012
    Awesome. I love acrylic-lit LEDs. As for photographing them...no, not really. I'm not a big photography buff. Sorry :/
  15. Ace_finland
    11 Aug 2012
    Yeah, its a nema 23 support :) well spotted!
  16. bluc
    4 Apr 2012
    Steller work love the overall design and the way you did the fan controllers:dremel:
  17. Ace_finland
    11 Aug 2012
    Thanks!
  18. Ace_finland
    11 Aug 2012
    Got some great news guys. After some discussions with EK Waterblocks they decided to sponsor me in this build!
    Since I started water cooling I have always liked the design of the water blocks that EK provide. So it is truly an honor to work with such a great company!
    The parts :)
    Unpacked
    This i won over at cooledpc.com but thought i would share it anyways
    Pump top to add some performance
    [​IMG]'
    EK-DDC X-TOP CSQ - Acetal, such a buty
    Waterblock for my Asus Gene-V, EK-MOSFET ASUS M5G
    EK-CoolStream RAD XT (240)
    A bunch of fittings, some i have bought and some sponsored
    EK-RES X3 150
    EK-FC5X0 GTX GW Backplate - Black
    New build update coming shortly.
    Special thanks to Gregor over at EK for helping me out!
  19. Ace_finland
    11 Aug 2012
    Sneak preview of whats to come, will update tonight if i got enough time
  20. Ace_finland
    11 Aug 2012
    Been quite busy the last few days having time off work in order to be able to finish the mod for the competition.
    Started with some motherboard raisers, was gonna machine them in aluminum but then i found this nice red Ø20mm plastic bar. Not the right red but they won't be seen after its installed and it's so easy to machine in plastic.
    First i machined them to the right diameter
    Drill and tap
    All done!
    Test fitted the pumps and the rads to check for clearance issues
    This looks a bit weird, but its in the middle of the case. Had to cut some space for the cables from the psu, this should be enough.
    All sanded and ready to get glass blasted
    Glass blasted and ready to be powdercoated
    It looks a bit uneven but its smudges from me fingering it, i didn't see it but it shows up in the photos, will clean it off before the final shots!
    Radiator box, or whatever you would call it
    Rear side of the same part
    Almost assembled
    And some final shots of the case itself, I really like the way it looks and glass blasting the acrylic made a really matte finish which hopefully will hide the single leds and give an even light throughout the acrylic.
    Still need to cut slots in some of the acrylic to be able to install all the leds.
    Also need to make something to hold the GPU's in place, i know what i want now so I just have to fabricate it.
    Stay tuned for more updates
    Sponsored by:
