Case Mod - In Progress Test bench mod by Ace_finland [completed]
Discussion in 'Project Logs' started by Ace_finland, 10 Oct 2012.
  1. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Coming along great man.
  2. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    I'll high 5 this. Looks fantastic!
  3. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    Red leds look amazing! Great effect with the plexi! ;)
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Coolest test bench I've seen, in 2011 this is totally 5 stars. :):dremel:
    In 2012 everything is being trashed it seems yet modding continues to get better.
    About the stupid ratings, head over here & cast a vote, it's unofficial but people who are bothered about the misuse of the system are trying to make bit-tech take note, some have been turning the rating system to meaningless dribble & it needs dropping.
    http://forums.bit-tech.net/showthread.php?t=250884
    Options are.
    1. Get rid of the voting system.
    2. It's a useful indicator (but it isn't anymore).
    3. Don't care.
  5. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    Thanks!
    Thank you!
    Thanks!
    Thank you! I'll check it out, not so bothered about the ratings :)
  6. Ace_finland
    11 Aug 2012
    New update! Getting close to the end of the Coolermaster competition! Have been very busy the last weekend, spent around 30hrs on the computer on saturday and sunday and had to take today off work just to get it up and running. Taking it to get photographed tomorrow so i can get some proper shots of it for the competition.
    Sorry if its not in order the update, a bit stressed due to still having a lot to do before the photo shoot.
    Anyways, gonna start with the parts. A lot of the parts are from my previous build but there are also new parts
    Coolermaster test bench
    Intel 3570K
    Asus Maximus GENE-V
    Corsair Dominator Platinum 16GB 1600MHz
    128gb OCZ Vertez 2 SSD
    Corsair AX850 PSU
    2 X Gainward GTX570
    2 x Lamptron FC5 V2
    4 x Schyte Gentle Typhoon
    A lot of leds
    Watercooling:
    2 x EK-FC5X0 GTX GW Backplate - Black
    2 x EK-RES X3 150
    2 x EK-DDC X-TOP CSQ - Acetal
    2 x EK-CoolStream RAD XT (240)
    1 x EK-MOSFET ASUS M5G - Acetal + Nickel
    1 x EK Supremacy cpu block
    1 x EK Dual parallell sli block
    2 x laing ddc pumps
    A lot of EK fittings
    Mayhem's Aurora tharsis red
    Sleeved the led wires, the cat loves it
    Installed in the acrylic
    The lamptrons installed
    Mounted the rads and the fans to an xspc rad mount, quite a tight fit, a little bit over 1mm to spare :)
    Plumbing done on loop 1, was a bit more difficult than i first expected. Ignore the blue cables, resleeved them after
    Had to check what it looked like with the Hyper212 that i've used during the build. Had to remove all the water cooling so i could get all the sizes right
    So many cables, had to cut every cable and shorten them, they would not fit in the case as is.
    Tried to get hold of some genuine CoolerMaster sticker but it was a lot harder than i expected. So contacted Coolermaster and got approved to make my own stickers. Was gonna go with normal stickers but due to the case is slightly textured it wouldn't look good so went with these polyurethane based "3D" stickers. Got a few different color combinations made so i could pick the one i liked the most. Big thanks to Mr Glasberg over at staffans.fi for making these priority 1 and making them in more or less a day
    Assembled and more or less ready to go. Still have a lot to do but this will have to do for the competition.
    Leak test ongoing
    Don't wanna post too many pictures of the bench, gonna wait until tomorrow after the "proper" photos are taken. Next update most likely tomorrow.
    Sponsored by:
    Fuganater likes this.
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Sweet lord that is awesome!
  8. Ace_finland
    11 Aug 2012
    Thanks, i've gotten a lot of inspirations from you renderings in the past! Love all of your builds!
  9. KrunchR
    22 Apr 2008
    Niiiiice!
  10. Ace_finland
    11 Aug 2012
    Cheers!
  11. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    oh wow the videocard mount matches the memory, that makes the mount even better :thumb:
  12. Ace_finland
    11 Aug 2012
    Was waiting for someone to notice, in due time the ram will match the videocard mount even better :) just need to figure out how to do it so it looks as standard ram but with acrylic in it :)
  13. Ace_finland
    11 Aug 2012
    Hey guys, pics will be up tomorrow from the photo shoot, until then a teaser :)
    and yes, i know i need to bleed the system again :)
    Sponsored by:
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks great. I can't wait for more pictures.
    Pet the cat for me. ;)
  15. Ace_finland
    11 Aug 2012
    thanks!
  16. Fuganater
    6 Jul 2011
    I keep forgetting how small this build actually is.
    Can't wait to see your final photos!
  17. Ace_finland
    11 Aug 2012
    It is quite small but it's very heavy due to the aluminum panels :) they will be up tomorrow!
  18. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    The teaser looks great :), some bleeding wouldt be a bad idea ;D
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Sweet sweet sweetness :):clap:
  20. Meelobee
    5 Nov 2003
    Good stuff Ace :)
