Case Mod - In Progress Test bench mod by Ace_finland [completed]
Discussion in 'Project Logs' started by Ace_finland, 10 Oct 2012.
  1. alain-s
    alain-s Active Member
    12 Jan 2011
    That is just amazing Ace!! Lovely Idea maybe U should contact Corsair and sit around the table with this great idea. :D
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Oh my god, thats lovely!
    Can you show a picture with the red one, Please!
  3. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks! Yeah, i have already sanded it but maybe a different grit. i've seen 3mm sheet of acrylic which have been several square meters big and in order to get a even light through the whole sheet they used a co2 laser to cut different sized grooves throughout the sheet in order to get an even light. This might be a bit overkill for a ram mod :) but the principle is the same if u use a co2 laser or different grit sandpaper :) So i will do some tests and hopefully i will get it sorted out.
    lol, i wish ;)
    I will experiment ta bit more cause the light is not spreading more than in the picture without the light bar.
  4. Fonne
    Fonne New Member
    9 Oct 2010
    Looks amazing, really nice work :thumb:
  5. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Brilliant idea on the ram mate!
  6. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    Grats on winning the CM Case mods comp Ace (scratch mods) Super build and well deserved. :thumb:
    Rip
  7. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks!
    Thanks! btw, you will have a pm soon :)
    Thanks! but it was in the tower mod section, after all it started as a cm test bench :)
    Thanks to all that has been following me this year and a happy new year to you all! Next post will be next year :)
  8. Dmlindley
    Dmlindley New Member
    24 Nov 2012
    This is certainly one of the best test bench's I've seen! Well done!!!
  9. Cheapskate
    13 May 2007
    Those ram covers are delicious.:D -NEEEEEED a picture with them with the whole case in the shot.
  10. Editor22
    3 Jan 2009
    Thought you might like to see this :D
    LINK
    Would seem that corsair liked your ram idea :D
  11. Guest-23315
    Guest-23315 Guest
    I like the fact Corsair feel the need to call and allen key 'an instillation tool'..
  12. Editor22
    3 Jan 2009
    rofl that's not just any allan key and screws though Mankz.... thats a Corsair allen key and corsair screws :D
  13. Guest-23315
    Guest-23315 Guest
    Since when did Corsair think they could compete with Marks and Sparks.. pff.
  14. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Hey guys!
    Back now, been very busy with work and a lot of other stuff.
    Have been trying my best to get the ram working but after corsairs "release" on monday i decided to shelf my idea.
    I tried making grooves and so on in the acrylic and i got the light to spread decently as far as the new corsair kits are covered. Maybe they had the same problem :D Anyways, I will move on to some other mods i want to try out instead. Updates to come as soon as i make some progress :)
    Oh, also got the Rig Of The Year over at guru 3D!
  15. bulldogjeff
    2 Mar 2010
    I missed most of this build. It looks fantastic, it's got a really mechanical look about. I love the lighting affects as well.
    Top modding dude :thumb:
  16. Editor22
    3 Jan 2009
    oh wow! congratulations mate!
  17. dream1
    dream1 New Member
    26 Feb 2011
    I really like how the plexi is designed in it and the mobo tray back OMG that is just beautiful. Great job.
  18. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks!
    Thanks!
    Thanks!
  19. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Hey guys! Seems like it was forever since i was last on, been so busy with work and life in general i have not had much time for modding. I did make a bunch of different backplates which i will hopefully post a pic of tonight.
    But for now i need your help.
    Sadly the coolant i used didn't work out so had to swap it to some normal cooling. This is when evrything went south and i have no idea anymore what's wrong. Hopefully some of you might have an idea.
    The problem is GPU #2 keeps rising until the computer shuts down.
    The loop order is res-pump-rad-parallell gpu's - res. The rad is an ek xt240
    On idle both sits around 5c over ambient, max on gpu is 57c, when i stop stress testing they bouth drop to 5 over ambient in a matter of min.
    If i swap the gpu's around it's the other one that overheats.
    What i have tried:
    - Cleaning out the blocks and reseated the blocks.
    - Checked the pump for flow and pressure
    - Flushed the whole system
    - swapepd around gpu's --> the other one overheats
    - checked that there are water in both gpu's
    - have bled the computers for hrs in evry possible position while running, def not air in the system.
    The only thing i can think of is for some reason there is not enough flow through the 2nd gpu block.
    Anyone have any ideas? I was thinking of getting a series block just to rule out the parallell block.
    Ace
  20. tekonivel
    tekonivel Member
    14 Jul 2012
    The problem might be the parallel block. i would change that first and see from there. serial makes sure that the liquid has to circulate trough both blocks.
    Good luck.
