Hardware Teufel Concept D 500 THX
Discussion in 'Article Discussion' started by arcticstoat, 15 Apr 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Toka
    Toka Minimodder
    19 Nov 2006
    Really? I do like Teufel stuff (specifically their DAC + speaker package) but £450?
    Connecting separates up in the same way as this offering you could go for
    Speakers
    Amp
    Cable
    What you loose in base you gain in detail and clarity. Possibly you might want to go for better speakers and a cheaper amp, the way round I have it is just the one I prefer.
  3. samkiller42
    25 Apr 2006
    This set is THX certified, hence it's price.
    Sam
  4. memeroot
    memeroot aged and experianced
    31 Oct 2009
    lol - just picked up a (formerly) 2k+ 6x power amp (thx) soundcard , 5 kef eggs and a (prev) 1.2k sub for total 400....
    wonder if it is better?
  5. Xir
    Xir Modder
    26 Apr 2006
    on normal Teufel Subs, you can set the crossover...maybe it's a THX requirement that it can't be changed here?
  6. mi1ez
    mi1ez Modder
    11 Jun 2009
    I'm with toka. Give me my hifi seperates any day!
  7. BobbySparkle
    BobbySparkle What's a Dremel?
    15 Apr 2011
    "This set is a far better option than hi-fi separates"
    Please quantify this, I'm currently running barracuda AC-1 card optically into a sony mds-920 (about 500 nicker in its day, though unfortunately limited to 48Khz) and then into an Arcam Alpha 7 amp, thats running Bi Wired Mordaunt Short 920s (pretty crappy speakers) coupled with a REL Q200e subwoofer.
    Are you seriously trying to tell me that this setup will sound better than what I am running........sound is a subjective thing obviously, but I really can't see it chaps. If you want good sound out of a pc - get the best soundcard and best dac you can afford, its taken me about 6 years and several sets of different systems including the likes of jbl, harmann kardon etc. to reach this conclusion, but am quietly confident it'll take the pepsi challenge with most out there without spending horrific amounts of cash
  8. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    If these make it to the elite list in CPC can you at least suggest a budget option as you do with GPUs and the like?
  9. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    no new scoring system? with all the tam tam you announced it, i would have assumed it would be omnipresent by now?
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    Don't worry, these won't be making the elite list. They're awesome and sound great, but we know only the minority want to splash this sort of cash on PC audio.
    Hifi separates are always going to be tough competition at this price, esp. if you buy your bits second hand on the cheap. For an easy one shot of uber audio though, these are bloody good.
  11. PlayedStation
    PlayedStation Possessed like an apostrophe
    21 Oct 2010
    can you run a competition to win the pair you tested please? and announce me the winner?
    want.
  12. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    I have the 5 Kef eggs. I love em. :)
    Personally I believe that speaker technology changes slowly. A set of high quality speakers from 10 years ago are still good now.
    But amplifier tech changes, so a 10 year old amp behind the times.
    So, if you are going to get into audiophilia, get the best speakers you can afford now, cos you won't be changing them as often.
  13. 3lusive
    3lusive Minimodder
    5 Feb 2011
    Would this get the 'extreme ultra' award?
  14. bcd
    bcd What's a Dremel?
    14 Apr 2011
    I concur, can't see why you'd feel the need to spend so much money on the amp though, the bottom-of-the-range Cambridge Audio amp would do you proud!
  15. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    stop comparing 2nd hand hifi kit to brand new pc audio on a bang/buck level.
    by all means compare new hifi gear to new pc audio. and perhaps each time hifi still wins out, but when you need to make the hifi 2nd hand for better value then its a skewed unfair comparison.
  16. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    I imagine having an amp built into the subwoofer, saves more space then having a big hi-fi amp and speakers. Also, it looks like they'd be slightly easier to wire up and get working. It's the old buy pre-built or build your PC argument. Personally I'm happy with my Q-Acoustic speakers, and Yamaha radio/amp, but I can see the appeal of these speakers.
  17. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    The waveguide on the tweeters looks very nice, albeit a little deep.
    They look like good performers but at that price there are better options. You can grab some nice powered powered monitors like the Yamaha HS80 for that price.
  18. wbdog206
    wbdog206 not me
    15 Jan 2007
    I still like my old tube amps.
  19. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    quoted for truth, at that price you get into getting studio monitors. I would pick up a pair of KRK RP8's or the yamaha HS80m. Also at that point you should start thinking of room treatment. I know when I put my studio monitors in an untreated room I got a huge bass increase that absolutely killed the highs. it was like a 6+db gain.
    here's where I would look http://studio-central.com/phpbb/viewforum.php?f=15&sid=a35e6fae62e20ac810739f14ed058afe powered monitors are what most studio guys use.
  20. Anfield
    Anfield Multimodder
    15 Jan 2010
    From the review:
    And then only a 7 for design?
    Anyway, good to see Teufel pushing the limits of Pc Speakers, but above a certain price point your just better off connecting the PC to a Hifi and not bother with separate speakers for the Pc.
Tags: Add Tags
