Scratch Build – In Progress Teybers Rotary Single Stage
Discussion in 'Project Logs' started by Teyber, 24 Dec 2007.
  1. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    yeah, only the middle link brings you to the imageshack site, no pictures.
    great build though. spent the last month learning about mechanical refrigeration and that stuff because of your log, impressive amount of stuff to do
  2. Teyber
    Teyber ******
    18 Mar 2007
    thanks!
    yeah im an idiot... ill re-upload the pictures afterschool today sorry about that :p
  3. Teyber
    Teyber ******
    18 Mar 2007
    alright guys just to keep you informed on the delays.
    Got a new car, so have been very busy with that. 2008 vw rabbit.
    Not sure if i said or not but the evap was completely clogged :cry: when i was brazing cap tube some of the brazing rod flowed all the way down in. Fixed clogging but now can't get it leak free, so i am starting a new evap.
    Broke 3 expensive endmills yesterday so lost motivation to mill lol :(
    So just decided to make a new evap for now.
    New one is shorter too. Old one was excessively tall, almost 1.6"! new one is about 1.25". I still need to machine the base down to perfect thickness and perfectly flat.
    Also the older style was not finished.
    Outside is a little rough, was using 1/8" endmill because i didn't want to change collets for 5 min of milling... gosh prolly should have but its not going to show.
    Tried to make inside have nice finish. Outside edges should have been done with one of my 1/4" carbide TiN(titanium nitrate) coated endmills.
    You can see i tried to have "tiny bit" of larger to smaller from base to top in center size...
    and new avvie :D
    New copper pipe comes in mail soon, found a good deal on 4' of 1.5" id 1.625" od copper pipe, i think 24$ and 16$ to ship. I was paying 40$ a foot before! (luckily i was buying in inches...) but still it added up.
    Regards
  4. fex89
    fex89 What's a Dremel?
    2 May 2008
  5. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    i noticed you were having trouble uploading pics of your vw rabbit so for those that don't know what they look like:
  6. Teyber
    Teyber ******
    18 Mar 2007
    i had that and returned it for reliability problems :p
    there we go
    and thanks fex :D
  7. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    What the !!! nice car. I like your evap, reminds of the chilly1
  8. mvagusta
    24 Dec 2006
    aaahhhh, the vw rabbit :duh: But do those things go well with the long legged busty redheads? Any mods planned? Maybe nfsmw has a bit to do with it, but those cars look pretty damn tough & sporty with a quick lowering job :naughty:
  9. Teyber
    Teyber ******
    18 Mar 2007
    thanks! oreon: it was a little bit more insired of kayls block, but thanks :D
    mvgusta: Lol! Thinking of struts bars and a cold air intake, not for a while. I don't want to worry about speed bumps so i will do some research on that. If i lowered it it wouldn't be by much.
    will post more pics once i find camera
  10. karolis
    karolis Code Monkey
    10 Mar 2008
    Amazing Teyber, simply amazing. Until yesterday i had no idea such thing as phase change cooling existed..
    Respect for you man. this is how technology is evolving - in garages of talented people :) Keep it up
  11. Teyber
    Teyber ******
    18 Mar 2007
    Thank you! appreciate the kind words mate!
    k brazed the maze evap. Did it with mapp, since im out of acetylene. Came out great, got it red hot but then as soon as i tried to braze in suction copper i failed lol.
    made the top:
    just slides in the bottum. i milled the bottum to make these fit.
    brazed
    Im willing to put money that this won't leak :p
    while heating the colors got very intresting
    cleaned
    Base not lapped... need to buy some 3/16" tube then i can braze that in and lap the bottum.
    Enjoy!
  12. Teyber
    Teyber ******
    18 Mar 2007
    lapped
    EDIT: i fixed link...
  13. karolis
    karolis Code Monkey
    10 Mar 2008
    uh, shiny :D
  14. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    ooh shiny and pretty blue colours... very nice
    reminds me of the metals i was heating up with the bunsen burner today in science.
    did you purge your evap when you brazed it or are you going to clean it up later???
  15. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I can only see little red x's. =(
  16. Teyber
    Teyber ******
    18 Mar 2007
    fixed pic sorry... stuey: you probably couldn't see it as i forgot to resize it and forum probably took it down.
    oreon: bunsen burners are fun! of course i purged the inside, outside i can't i just clean it up after. It ruins the thermal transfer to not purge. The purple/blue is pretty cool huh? weird to see copper that color...
    thanks karolis :D
  17. Stuey
    20 Jan 2005
    Nope. I'm still seeing red X's, and clicking on them leads to a "cannot be found" error.
    Actually, after looking at other pages in the thread, it looks as though all of your photos are down.
  18. haakon.t
    haakon.t :)
    8 Dec 2007
    all the photos are working perfectly here...
  19. Stuey
    20 Jan 2005
    It seems that I am randomly unable to view any imageshack photos at the moment. Odd.
  20. Cheapskate
    13 May 2007
    Off topic: Don't lower your ride. I have a friend with cronic back problems caused from his love of lowriders. Roads are rough enough without you removing some of your cushion.
    The same friend once hit an object in the road in a lowered VW. The passenger seat was sucked under the car when it caught the floor pan.
    Here's the best part. the road object was a manhole cover.:D
