TFT Decision- which of these 2 17"? NEC vs Hercules!
Discussion in 'Hardware' started by Phrozenpenguin, 3 Nov 2003.
  1. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    OK.
    I have the option of keeping one of the following TFT's
    NEC 1701
    Hercules ProphetView 920
    Both are 17", both are mainly black, both have only D-SUb analogue input. Hercules has external power brick, NEC is built in.
    Quality is not an issue, i reckon the picture is spot on in both, and neither have dead pixels :)
    PICTURES HERE!
    Which do you think i should keep? Im thinking NEC atm....
    I have been using the hercules for the past month or so, and am not sure i like the bevelled edges.
    Opinions pls ppl!
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    I prefer the plainer looks of the NEC myself :)
  3. Phrozenpenguin
    11 Dec 2001
    Cheers. I am leaning that way to!
  4. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    Me likes Hercules and black components in general .
    Black looks more "Technologic" :D
  5. DamoW
    DamoW What's a Dremel?
    2 Nov 2003
    I reckon the NEC - nearly bought one myself, can't fault them on looks.
  6. SugarBear
    SugarBear What's a Dremel?
    20 May 2003
    the NEC, it's the all around better monitor, although I like the looks of the other, except for the odd button placement.
  7. Guest-16
    Guest-16 Guest
    NEC, although bear in mind you dont get a DVI cable with either i dont think. Not like the LG1710b which has everything and is exceptionally lovely and you should buy it from amazon or MD for £330.
    Half a dozen converts and counting :D
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    NEC...
    no contest.
  9. DamoW
    2 Nov 2003
    I've just bought a couple of 17" Hitatchi CML174SXB's - cost me £340 (each obvsly!) from Scan.
    16ms response time, A1 clarity/colour... mmmm... very nice. :D
  10. Tim S
    Tim S OG
    8 Nov 2001
    I prefer the NEC
  11. Phrozenpenguin
    11 Dec 2001
    I have both these sitting on my desk, so i wont be buying another :/
    If i realised i may have got an LG over the NEC, but too late now.
    So not many hercules fans here?!
  12. neonplanet40
    neonplanet40 What's a Dremel?
    3 Mar 2003
    I prefer the Hercules........... I think it looks the part and does really well in reviews. Comes from a very respectable country. Make any computer look gd TBH! :rock:
  13. neonplanet40
    3 Mar 2003
    Excuse ym spelling ppl country is suppost to be Company!! soz
