Thanos - Thermaltake CaseMOD Invitational Season 1
Discussion in 'Project Logs' started by warboy, 18 Jul 2021.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    2021 Thermaltake CaseMOD Invitational Season 1 has started!
  2. warboy
    24 Nov 2011
    Here is the beast! The Case Thermaltake Core P8!!
    we started by disassembling the case:
  3. warboy
    24 Nov 2011
    We continue printing the bad guy: Thanos [​IMG]
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I got 9 printers now and you think i get to use one to print a case mod part :wallbash:
    I like that you didn't go with the movie Thanos.... i'm so over movie/game themed case mods.
    warboy likes this.
  5. warboy
    24 Nov 2011
    After about 280 hours of printing here is Thanos. Ready for sanding.
    But first I give it a coat of epoxy
    Jean R built and Cheapskate like this.
  6. warboy
    24 Nov 2011
    I paint thanos to bring out the gluing and printing defects.
    Now I start grouting with epoxy putty. It will be a long job
    [​IMG] [​IMG]
  7. warboy
    24 Nov 2011
    We continue to sand and fill ... fill and sand ... a few more hours and it will be ready for painting
  8. warboy
    24 Nov 2011
    In the meantime, other components are on the way:
    ARGENT M5 Wireless RGB Gaming Mouse
    ARGENT MP1 RGB Gaming Mouse Pad
    ARGENT HS1 RGB Headset Stand
    ARGENT H5 Stereo Gaming Headset
  9. warboy
    24 Nov 2011
    We are continuing to print parts of our custom PC .
    For now we have used about 15 kg of PLA
    Cheapskate likes this.
  10. warboy
    24 Nov 2011
    Here are some photos of the hardware, let's start with the RAM:
    TOUGHRAM XG RGB Memory DDR4 3600MHz 32GB (8GB x4)
  11. warboy
    24 Nov 2011
    In the meantime we are proceeding with the gluing of the parts.
  12. warboy
    24 Nov 2011
    Then we continue to fill and sand the printed parts...
  13. warboy
    24 Nov 2011
    and now some #### hardware [​IMG]
  14. ItalianExtremeModders
    ItalianExtremeModders What's a Dremel?
    12 Sep 2020
    We continue to sand and putty the pieces until they are perfect
    The next step is painting with a primer and then we mask some parts
    We paint with a chameleonic purple with blue reflections.
    Then we finish with an opaque clearcoat.
    the masked parts will be painted in metallic gray
  15. ItalianExtremeModders
    12 Sep 2020
    Let's move on to Thanos painting. Let's start by masking the parts that will be painted gold.
    [​IMG][​IMG]
    After painting the thanos suit, I mask the suit to paint the armor.
    Here are the first layers of the golden color.
  16. ItalianExtremeModders
    12 Sep 2020
    Then I add some details, and I'll finish it with the airbrush.
  17. ItalianExtremeModders
    12 Sep 2020
    We've finished printing the back of the throne! over 200 hours of printing;)
    After coating with the epoxy, I continue to grout to prepare the piece for painting
  18. warboy
    24 Nov 2011
  19. warboy
    24 Nov 2011
    [​IMG][​IMG]
    censored_Prometheus_ likes this.
  20. warboy
    24 Nov 2011
    now we start designing the base of case P8
