The £10 plastic case mod...
Discussion in 'Project Logs' started by bwgames, 18 Dec 2004.
  1. bwgames
    bwgames Minimodder
    6 Dec 2004
    Or.. . The quick 4-hour case mod...
    OK, so I was down at my local plastics place, and picked up a 2ft square sheet of 2.5mm poly for £8.
    I already had:
    A XP1600+
    Shuttle MK35N mATX mobo
    mITX PSU
    Various harddrives
    Laptop CD drive...
    Now, be warned, I wasn't looking for perfection in this. I needed a small case with computer in to take down to familys for the Xmas do (and didn't have much time...) plus I didn't want anything big.
    <Pics to follow when I get back from mates with jigsaw...>
    Edit: Pic of all the bits and some marking out done prior to jigsaw-joyness.
    Bits + the plastic sheet:
    The mobo standoff holes (memo to self: need plastic hole filler):
    More to follow..
  2. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    it isn't a project log untill you post pictures...
  3. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    What are you planning on doing with this then? Warning that obviously 2.5mm isn't thick enough to create a box, so I'd like to hear some plans ;) Good Luck
    <A88>
