Build Advice The £100 Gaming PC project
Discussion in 'Hardware' started by Parge, 2 Mar 2011.
  1. Parge
    16 Jul 2010
    Steam was taking an age to d.l BC2 etc! I think its everyone buying Shogun 2! Anyway, I've left it running all day today, so it should be done by the time I get home - I'll be able to get some stuff up later!
    Also gotta tweak that OC.
  2. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Looking awesome thus far, and im glad my Wirless card had a use, good job it was tiny!
    Keep up the good work : )
  3. Parge
    16 Jul 2010
    Ok so down at stock volts now, the CPU seems fine, as its passed 30 mins of Prime95. Temps maxed out at 61C
    I'll run it for 8 hours tomorrow while I'm at work.
    BC2 benchies incoming!
    *Update*
    Run 1
    1366 x 768, 2xMSAA, 'High' quality settings
    Highest: 69
    Lowest: 15
    Average: 29.9
    - this was too much for the poor old GPU really, when smoke came about it bought the framerate down to about 24fps, which is too little for an fps
    Run 2
    1366 x 768, 1xMSAA, 'Medium' quality setings
    Highest: 79
    Lowest: 31
    Average: 49
    - this, to me is fine, the game doesn't look as pretty as I'm used to, but its perfectly playable!
    sotu1 likes this.
  4. chrismarkham1982
    chrismarkham1982 Well-Known Member
    1 Apr 2010
    looking good, just shows what you can do with very little outlay
    definate +1 rep for you sir:thumb:
  5. Parge
    16 Jul 2010
    3D Mark Vantage
    Detailed scores3DMark Score 5864.56 3DMarks
    Graphics Score6345.15
    CPU Score4778.73
    Jane Nash19.69 FPS
    New Calico17.44 FPS
    AI Test644.81 operations/s
  6. Ferrero94
    Ferrero94 New Member
    15 Oct 2010
    nice job altough are you keeping it, selling it or giving it to that friend?
  7. Parge
    16 Jul 2010
    I'm giving it to my housemate to use, so he can play BFBC2 and SupCom2 with the rest of us PC gamers!
  8. mrbungle
    20 Sep 2004
    Decent build.
    Shame the card just doesnt quite have the puff i thought it would.
    Still plays with a bit of fiddling.
  9. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    Have you overclocked the GPU?
  10. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    He just needs a mic now. :thumb:
  11. Ferrero94
    15 Oct 2010
    and going with the frugal way, this should be plenty!
    http://www.play.com/PC/PCs/4-/6738074/Plantronics-GameCom-367-PC-Gaming-Headset/Product.html?searchstring=headset&searchtype=PCSH&searchsource=0&searchfilters=s{headset}%2bc{420}%2b&cpage=2&ob=4&urlrefer=search
  12. Parge
    16 Jul 2010
    That mic costs 38% more than my case, PSU and DVD drive combined! Extortionate!
    Oh god I've turned into a scrooge!
  13. Ferrero94
    15 Oct 2010
    Oh noes! you should see what i just edited in then D: ( i use them and they are EPIC, apart from when you use the onwire volume changer that makes changing the sound "scratchy" )
  14. GeorgeStorm
    16 Dec 2008
    Just wanted to say well done, is awesome to see what can be done on such a small budget.
    You've inspired me to possibly try and make a cheap LAN rig (will cost more than yours probably, but still not bad)
  15. Parge
    16 Jul 2010
    Hey mate, yes, its at 790 Core 990 Mem - couldn't get Afterburner to unlock despite following the online instructions to a tee.
    My cfg file seems slightly different though, as it has two values for enableunofficialunlocking
    'EULA' and 'Mode'
    Anyhow, changed both and neither seemed to work!
  16. Parge
    16 Jul 2010
    Thanks mate, good to hear. Its actually been even more fun than building my main rig was! It just proves, you don't need to spend the earth to play PC games nowadays.
    The 9650 (as I'm calling it - because that is also the total cost) is great, most games play at approaching max details at 1366x768, though for BC2 I'd probably like a little more graphical grunt so further down the line I might upgrade the GPU to a 4890/Geforce 216.
  17. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Based on your results and my own testing when I ran my GTX460 on a E2160 @ 3GHz you are being held back (to a degree) by the CPU. A Quadcore CPU (or even a tri core CPU) would offer a noticable boost even with a relatively weak GPU. Obviously this isn't going to happen within the budget allocated but it is worth noting for potential future upgrades.
    This is quite noticable with the M11x. Both revisions run a GT335m (think GT240 downclocked) with the main difference being the CPU. The Core 2 in the R1 struggles without alot of tweaking whereas the Core "i7" (i5 really - dual core with HT) in the R2 handles the game without an issue. This was confirmed both through benchmarking and loggin of the GPU utilisation in afterburner (~45% for the R1 and 90% for the R2).
    Sorry for the off tangent reply. Owning a R1 it is something I have spent ALOT of time investigating and hence I do tend to waffle a bit.
  18. Parge
    16 Jul 2010
    Quite a good article on Dual Cores vs Quad Cores here.
    The quads have far better minimum fps, but I definitely feel that a GPU upgrade would benefit games better for every pound spent.
  19. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Parge, truly impressive work. Hats off to you for doing something spectacular!
  20. xaser04
    27 Jun 2008
    Yes, sorry, you are quite correct that a faster GPU would offer a bigger benefit overall than a Quad core CPU. I was merely talking in regards to BFBC2.
    It is the same thing with the M11x (yes I am back on that again). The R2 offers much better performance in BFBC2 but near identical performance in most other games (say for example Crysis 2).
    Of course there is the question of balance but when you are working with a very tight budget you (as you suggest) upgrade the one component that will make the biggest difference in the round (as long as the tradeoff is performance in other things is "acceptable").
