Yes, fan noise is something I need to address in my Q1 Pro... Honestly the noisiest one is the power supply fan because it's running all the time. That'll be a simple fix though - just replace it with a Meanwell PSU. The chamber circulation fan is a 60mm jobbie, so I should be able to source a suitable low-noise replacement. Though I'm pretty sure the PSU is 24v rather than the 12v that PC fans usually expect - need to remember that and not blow up a shiny new Noctua .
Noctua's 24v fans are only 40mm, 120mm and 140mm. You can run a 12v Noctua fan off a buck converter, or track down a quiet 24v fan with decent airflow - most are noisy or fairly weak, but it's only for exhausting a cabinet; albeit through a filter box.
Straight away, but I just did the Paypal pay in three thing, since it won't ship until August. iirc, total was £425 for the printer, accessory bundle inc extra print head, extra filament reels and shipping. This was the extent of the order:
I just pulled the trigger on it (they do charge straight away), as I found there was a hidden extra £20 off for the FBT package with the 0.2mm nozzle and black filament, that made it only £388! And as far as I can tell, it also comes with the 0.4mm nozzle too! Shipping is still August, but might come sooner!
Seems to be a mixture of stock from different production runs too. Some people have received printers with the updates applied and others, receiving theirs later are getting theirs with no or fewer updates. I'm hopeful an August shipping date means all the improvements to date.
You're correct. The printer comes with an 0.4mm hotend as standard, the FBT package includes a second (selectable) hotend. Elegoo do not (yet) supply extra nozzles, just hotends. Hopefully, my order of 3Kg of PLA-CF should arrive today...
Personally I don't want the stuff in my home, as I've dealt with CF before and its utterly horrible, and this will be micro particles of it! It will be a cancer risk!
i have so far stuck to PLA and PETG, i want to try some CF filament for bits on my motorbike but with kids using our 3d printer i am not going to this guy did a a couple of videos of the down sides with CF
You have me seriously considering the Elegoo. What all would I need for nylon? A reel dryer? I'm pretty sure I'll make a secondary carbon filter and fan box to force that sh*t through an extra couple of pounds of aquarium carbon.
Technically... nothing. It's compatible out of the box. But on a practical level, yes, you would very much want a filament dryer for nylon, preferably something that you can print from. And yes, chamber filtration is almost certainly a requirement once you move past PLA & PETG. As far as I know, there is no active filtration on the Centauri Carbon out of the box. But there are always 3D printable options, or ducting the exhaust externally if your space allows for it. From what I gather, it can be a bit of a pig of a material to work with, even on the best of printers.
Its only machines like the SLS that do it well, but then there's the hell of post-processing! I always outsource nylon 3D prints!
