Modding The 3D Printing Thread
Discussion in 'Modding' started by SkiDave, 6 Jun 2015.
  1. Cheapskate
    13 May 2007
    I'll be making stuff like a 30 year old hood prop catch. It doesn't need to be pretty, just survive next to an engine radiator.
    ABS will be a lot of what I do as well, and I KNOW that stuff stinks.
    -Of course... I might want to draw up some absolutely apesh*t computer designs as well.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Honestly, I'd prototype it in PLA then make a final part from a production service. I've used Protolabs and Solidprint3D, but were really cheap and produced way higher quality parts than I could print with the Ultimaker S5 I have at work. That'd be my recommendation for parts like this :)
    Byron C, Yaka and Arboreal like this.
  3. Yaka
    Yaka Multimodder
    26 Jun 2005
    thats nice to know do those services give the CF stuff a coot of sealent as well or do you do it your self?
  4. Bloody_Pete
    11 Aug 2008
    Not used CF, but they can vapour smooth nylon, which will have a similar effect :)
  5. David
    7 Apr 2009
    Another dispatch notification from Elegoo. *Gasp*
    This time it's just the extra accessory pack.
    Boooo!
    I know it said August and I'm just being irrational, but @IanW planted a seed that it might be delivered early, so it's his fault really.
    Arboreal, Byron C and IanW like this.
  6. Cheapskate
    13 May 2007
    :worried: Pulled the trigger. Now we wait. -Not like I'm in a position to play with it anyway. I'm up to my 3rd raccoon corpse this month.
    Arboreal likes this.
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I ordered the printer during the launch stream on February 17th. It arrived March 28th.
    I ordered the accessories & some filament only 2 days after the printer (Feb 19th). The accessories arrived last week & the filament this Tuesday.
    David likes this.
  8. Arboreal
    21 Jan 2011
    Cheaps, what are you doing to the 'poor trash pandas'?
  9. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    I was afraid to ask that question tbh! :hehe:
  10. Cheapskate
    13 May 2007
    The mom abandoned them when we put on the new roof. I'm replacing the soffit and facia. Tenants were trash and I could write a book here on what I'm cleaning up, but I shouldn't.
  11. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Wasnt sure where to ask im after a 3d printing service that wont break the bank, i need two items for my new pc printing but no clue what i need to look for. And the only person i can find that sells them printed is in canada and i ideally need the parts this weekend
  12. Byron C
    12 Apr 2002
    Do you have a link to the file?
  13. Arboreal
    21 Jan 2011
    You have my sympathy Cheaps. I do what you do but on commercial property.
    Small workshops and offices mainly.
    Just evicted a non paying tenant and going through the piles of rubbish, furniture and stuff they left behind after supposedly clearing out.
    Thankfully the 2 trucks outside have been removed, which would've been a problem to dispose of.
  14. Kehoe
    Kehoe Minimodder
    9 Aug 2015
  15. Byron C
    12 Apr 2002
    That’s not a terribly complex model, it won’t be a challenge for a modern 3D printer and certainly not something to trouble a commercial service.
    You’d definitely want it done in PETG, there’s every chance that it’ll be exposed to temperatures that could soften PLA (roughly around 50C-60C, but it depends on the manufacturer, some can even weaken at temperatures as low as 40C).
    I’d offer to print it myself for you… but I don’t have any white PETG, and I’m not sure how much is left on the reel of black PETG filament I have. My printer’s been idle during the heatwave, and there’s a case panel for one of my own projects waiting to be printed.
    If I get time tomorrow I’ll check out my filament supply situation, but in the meantime JLC 3DP is one that I see talked about a lot. But that certainly won’t get here by the weekend, ‘cos they’re in China.
    Kehoe likes this.
  16. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Hunting for someone one on etsy to print this file, dont want to spend to much as i dont even no if it will 1000% reolve the issue might have to swap my psu that i go :-(
    So far been quoted £15 delivered does this seam ok ??
  17. Bloody_Pete
    11 Aug 2008
    Shoot a message to the team at Solidprint3D, they do small batch printing on their demo systems. They have a Formlabs Fuse they'd easily do it in Nylon, and they offer vapour smoothing, they also have other machines too. Been fairly cheap for parts I've had run, but they were totally different dimensions, so it's hard to estimate pricing.
  18. David
    7 Apr 2009
    I bought a few used GPU mining frames dirt cheap to harvest the 2020 Alu extrusion to make stuff. In this case, the stuff is a simple workstation frame for my new printer, when it arrives.
    I wanted the 2020 extrusion because you can rig up hangers and storage bins straight off the framework. I also have a 7' x 3.5' x 1" pine table top that I saved from the scrap bin at work, so it'll have a fairly sturdy worktop and shelving. I had a handful of brass M6 threaded inserts too, so fitting the wooden parts should be a reasonably neat affair.
    I have a question though... should I put heavy duty casters on the frame, or will that introduce additional unwanted vibration?
  19. Byron C
    12 Apr 2002
    You probably want it as stable as possible. IIRC the Carbon uses a Klipper variant so you’ll have input shaping to compensate for resonance/oscillation, but I still wouldn’t fancy using even lockable castors. That print head whips around something fierce at times, I’m not sure I’d trust castor brakes/locks to stand up to it!
    I do use some TPU feet on my printer to reduce the transmission of vibrations through the floor/ceiling, but TPU is not a super squishy material so it doesn’t introduce much additional movement. Input shaping seems to cope with it just fine.
    IanW, David and Arboreal like this.
  20. David
    7 Apr 2009
    After giving the idea a good dose of thinking at, I reckon I might get a set and try it out. There are some casters that retract inside the feet rather than just lock, which might be a better idea, as it's unlikely I'll be shifting this around on a daily basis; but the ability to do so could be a handy feature.
    Bloody_Pete and Byron C like this.
