Modding The 3D Printing Thread
Discussion in 'Modding' started by SkiDave, 6 Jun 2015.
  1. Gareth Halfacree
    4 Dec 2007
    There's a bunch of silica gel sachets in the boxes. It's probably below 10%, even, but that's as low as the cheap hygrometers read!
  2. David
    7 Apr 2009
    If I dump a couple of hygrometers in a tub of fresh silica gel and nothing else they won't get that low.
  3. Gareth Halfacree
    4 Dec 2007
    They agree within a reasonable margin of error to a more expensive air quality monitor when out of the boxes, but I can't swear to their absolute accuracy at the top and bottom ends of their ranges - they came free with the cereal boxes!
    That said, I don't think they can be too far off: the Creality drying box, which I assume has a better sensor in it, says 15% RH when I put one of the spools in it. Room is maintained around 55% RH.
  4. David
    7 Apr 2009
    15-20% is really really good. 10% is pretty much unheard of even via filament dryers, from what I've read. My room is usually around high 30s RH based on a couple of those cheapo hygrometers and three Bluetooth devices - no active air conditioning beyond a couple of mobile air purifiers. I've never registered filament drybox RH below 15%.
  5. pete*
    pete* Just. Useless.
    29 Apr 2009
    And I thought my 13% was bad... If i'm reading it correctly. Gets down to 12/13% most of the time in my Creality Pi thing.. :hehe: I've got something doing well for once. :lol:
  6. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    I usually see around 20-25ish RH in my dryboxes. The room everything is kept in usually reads around 40-45ish, so they’re doing some good at least.
  7. David
    7 Apr 2009
    They sent a replacement hot end PCB with the new USB C cable...
    Moar spares
    Arboreal, Cheapskate, Byron C and 2 others like this.
  8. Gareth Halfacree
    4 Dec 2007
    First overnight print:
    Two-part case for the DJI Neo 2 - basically the same as the one I bought from AliExpress, except this works with the Video Transmitter still installed *and* has two clips for spare batteries.
    It works absolutely fantastically, no complaints there... but I'm seeing the same problems as before with overhangs, coupled with what looks like an under-extrusion problem (at default settings, no less.)
    The weird part with that crunchy bit above: the identical section on the other side of the spine is fine! (Well, on the wall of the case - the overhang on the clip is still crunchy as hell.)
    205°C initial temperature, raised to 215°C when I saw what looked like under-extrusion in the first couple of solid layers after the infill, 300mm/s print speed, 0.1mm layer height, 15% 3D infill, three walls, five upper solid layers and four bottom solid layers, other than that everything at the defaults.
    About the only thing I haven't tried is Flashforge's eff'd-about version of Orca Slicer, 'cos that's only available on Windows. So, guess I'm pulling one of the Windows laptops out of storage at some point.
  9. pete*
    29 Apr 2009
    Looks like most of my prints. :hehe: Overhang/stringing and weirdness.
    But prints Benchys pretty much perfectly (compared to actual prints). And the calibration towers for temp/retraction etc all come out looking great.
    Gareth Halfacree likes this.
  10. Byron C
    12 Apr 2002
    From what I understand, PLA's glass transition temperature is around 55-60C, depending on the specific composition. But many report that some PLAs have been known to soften at around 40C - The Q1 manual, and stickers on the printer itself, instructs you to leave the door open and remove the lid when printing PLA, for exactly this reason.
    Chamber temp 42.8C...
    Well... it's a good thing I'm not printing PLA...
  11. David
    7 Apr 2009
    Ooh, I should get my ASA on.
    Man cave agrees
    Byron C likes this.
  12. Byron C
    12 Apr 2002
    IanW likes this.
  13. Gareth Halfacree
    4 Dec 2007
    Think I'm going to have to come up with some other way of labelling these disk boxes...
    'cos my vinyl labels do not stick to 3D-printed PLA...
    pete* likes this.
  14. Cheapskate
    13 May 2007
    It might not work with pla well, but, acetone + glass + a little weight = smooth, flat surface. I've been doing this with PVC moulding cuts and pvc pipe glue for years.
  15. David
    7 Apr 2009
    I printed a label with raised text in a different colour then glued it to the container.
  16. David
    7 Apr 2009
    Elegoo are currently offering the Centauri Carbon with the multi colour kit for £272
    Byron C likes this.
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You can have the printer next week, but the canvas kit won't arrive until mid-October.
    Then you need an hour or two to fit it (they do supply all the needed tools though)
  18. Gareth Halfacree
    4 Dec 2007
    Another practical print:
    Ergo stand for the Kensington Slimblade. I did it at a 0.08mm layer height, but forgot to turn the speed down so the layer-lines are invisible but there's a sort of diagonal pattern to it instead. You can't really see it from a distance, tho'.
    It's designed to eliminate the forward tilt and instead tilt it to the right. Dunno if I'll get on with it, but for 80p's worth of filament figured it was worth a go!
    EDIT:
    I'll be honest, it feels weird!
    Cheapskate, Byron C and IanW like this.
  19. Cheapskate
    13 May 2007
    Test print :thumb:
    The tape slipped. It's a better fit than it looks like. The best part is pla can be bonded to this pvc with pipe glue. I plan to model common floor trim types to make indestructible corners. There's a few spots in the rentals that get the SH*T kicked out of them and I have to rebuild them repeatedly.
    IanW, pete*, yuusou and 2 others like this.
  20. pete*
    29 Apr 2009
    How am I supposed to know which wire is positive and negative on this fan? Arctic p12 slim PWM pst.
    Have to put a JST-XH connector on as plugging into the PSU.
    The sleeving is all black. One wire on the sleeving has a white line down it. ;/
