The 9GHz Rendiathon
Discussion in 'Article Discussion' started by WilHarris, 7 Oct 2004.
  1. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I like this mod very much, very well planned and worked out.
  2. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    Wow, that must use a lot of power!
    I never knew about this network rendering dealio. I do a fair amount of rendering myself also. Good job!
  3. ozzy99
    ozzy99 What's a Dremel?
    8 Oct 2004
    hello,
    I love yor render farm... :thumb: :clap:
    Do you have to use a diferent software licence (3dsmax) on every machine to network render?
    thanx
  4. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Agreed, exceedingly impressive. Great job :D
  5. PoW
    PoW What's a Dremel?
    24 Nov 2002
    This is really remarkable, I am interested in how the software on these systems is configured as that isnt highlighted in the article. What os is running on these boxes and how are they configured so they automatically divide tasks up in such a way.
    This is giving me all sorts of ideas!! Thanks a ton and great job!
  6. fathazza
    fathazza Freed on Probation
    20 May 2002
    been eating lots of mr kipling's cakes recently :baby: ?
  7. TMM
    TMM Modder
    12 Jan 2004
    Nice!
    its an awsome idea and well executed, although it would be a right pain in the bum if there was a problem with one of the mobos, or something on one of the mobos. looks like it takes a while to assemble and dissasemble the "stack" :p
  8. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    There's a couple of questions the come to the fore...
    He didn't mention if he's using 10/100/1000 ethernet connections...
    He didn't mention the OS he's running on any of the systems nor how he setup them in concurrent connection (something good I hope like clarkconnect)...
    I'm guessing he most likely didn't use windows clustering support with remote desktop...
    I would really like to know how he setup the software...
    Awesome mod though! Really gets deserves a :clap:
  9. olv
    olv he's so bright
    23 Sep 2002
    He did say that he was using a 10/100 switch.
  10. Goldberg
    Goldberg What's a Dremel?
    27 Aug 2003
    How did you get the powerbutton to work on all 5 systems at once :confused:
    I'm looking for something simular for my two server systems.
    great job :thumb:
  11. SleeperDC
    SleeperDC What's a Dremel?
    29 Oct 2002
    awesome performance for the price
    question:
    is this a home made blade server?
    if not, how is a blade server different from this amazing project?
    also waiting for answer for questions asked few posts up.
    OS? software support?
    Cheers
  12. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Blade Server
    These systems are quite a recent phenomenon. A Blade Server is a computer system on a motherboard, which includes processor(s), memory, a network connection and sometimes storage. The blade idea is to address the needs of large scale computing centres to reduce space requirements for application servers and lower costs. A typical application could be serving web pages. So along with a Storage Blade they can be rack mounted in multiple racks within a cabinet together with common cabling, redundant power supplies and cooling fans. Blades can be added as required, often as "hot pluggable" units of computing as they share a common high speed bus. Most of the Computer Manufacturers are now offering these computing elements, although some concerns about a lack of standards is currently being expressed.
    It could be considered a home made blade server.
    Mental Ray : Mental Ray is a powerful rendering system fully integrated within 3ds max. It was previously
    available as an optional package, but this version makes it available as a standard feature.
  13. kickarse
    6 Oct 2004
    awesome
  14. Audiophil
    Audiophil What's a Dremel?
    25 Jan 2004
    Absolutely amazing. D@mn good job! :rock:
  15. MartinB
    MartinB What's a Dremel?
    18 Jun 2004
    From what i know about setting up a render farm, each of those computers would be setup just like a normal computer with win2k/winxp on and then just networked together with some remote admin program to save you swapping the monitor cable about.
    On his main machine that he uses to actually make the 3d work, you'd install the server program and then on each of the 5 render comps you'd install the client software.
    When the software is all configured (found each other on the network and got permissions set up etc) you can then setup what you want to render from the server program. You could assign 2 of the client comuterss to each start rendering out individual frames from one scene, then tell another 2 comps to both work on the same frame from a different scene and you could have the last computer working on another scene file.
    The server computer will them make sure each client computer is supplied with the files it needs to complete the render (model files, colour/bump/specular maps, cached data from simulations etc) the client computer will do its assigned tasks and send back the rendered frames (either whole or split up to be combined with another) to the server computer.
    So they aren't actually a clustered or anything, just 5 networked computers with the software splitting up the jobs, there's a company that make small render farms, they do one called the Render Cube (link below) Its a big cube with a duel cpu motherboard on each side and all the gubbins in the center. An 8 cpu renderer but it costs around $10,000
    http://www.cgtraining.com/catalog/product_info.php?products_id=74
    There's this one company that do a render farm on a PCI card, it has 8 AR350 Raytracing Processors on it that are made specifically to do repetative rendering calculations. You can put 2 in a computer so you'd have 16 little rendering cpu's in a comp.
    http://www.art-render.com/products.ihtml?page=pureoverview
    Thats all i can think of at the moment, i'm really rather stoned at present, just waffled on loads talking **** :)
    Take Care
    Martin
  16. 1-Man-Army
    1-Man-Army What's a Dremel?
    21 Dec 2003
    hey i was wondering would this work, on video editing??? like eg TMPGEnc, it would surly speed up my dads time he spends on editing movies.
  17. stephen2002
    stephen2002 What's a Dremel?
    23 Sep 2003
    Not unless you manually broke your video into little pieces and set up one computer to render each one.
    These things work great for CG stuff because a CG video is just a lot of little frames, so for 50 frames you would assign 10 frames to each computer and let them chug away individually. You can do this with special software, typically included in most CG packages, or manually.
    But without the speical software it dosn't take advantage of the different systems.
    VERY cool by the way.
  18. inzane86
    inzane86 engineer with an axe
    15 Jan 2004
    Just on question what OS do you use in the server?
    Is it a windows or a linux or maybe some flavor of BSD like FireFlyBSD.
  19. Vigfus
    Vigfus Born to be...
    9 May 2004
    So cool :thumb:
    IMO a single power-cable would look nicer. And maybe ducting all the exaust to a single, larger, port.
    Is it real noisy?
  20. MrDT
    MrDT fapfap
    14 Jun 2002
    very impressive!
    the 400% increase in throughput speed is just crazy (i wouldn't expect it to hit 300% tbh, considering the better quality components his 3ghz rig has doubtless got compared to the 5*1.8ghz farm)
    it's incredible that all this fits in a fairly small enclosure too :eeek:
    nice planning, nice implementation, nice job :thumb:
Tags: Add Tags
