The 9GHz Rendiathon
Discussion in 'Article Discussion' started by WilHarris, 7 Oct 2004.
  1. sctool
    sctool What's a Dremel?
    15 Jul 2005
    i guess if you wacked a load of fast GFX in it you could play 5 mulitplayer from it!
  2. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    Wow - good luck to him on eBay. I don't think crazy stuff like this is very popular on there - it should go to a good protein-folding home or something.
    The only programs that can use all five processors are ones specially designed for multi-processor use. That normally means scientific simulation-type stuff, but also extends to 3D rendering software like 3D Studio. All these applications perform complex calculations over hours & hours, and so the workload can be distributed across several machines ie a render farm.
    You can't do this with games - most of the load is on the GPU rather than CPU anyway - and it most certainly will never speed up burning of DVDs - that is dependent on the drive electronics.
    In summary, if you're running SETI, or folding proteins, or making Shrek 3, then this machine will have a combined performance of close to 9Ghz (5 x 1800). If you want to play games etc on it, it will only be as good as a single 1800 Duron ie pretty slow.
Tags: Add Tags
