Cooling The ACTUAL merit of system blowers
Discussion in 'Hardware' started by Moyo2k, 10 Aug 2009.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I've seen a lot of system blowers around and have been pondering the ture merit of these?
    http://www.overclock.co.uk/product/...-Cooler,-Dual-Expansion-slot-cooler_7490.html - this one can move 35CFM at a pretty loud 30dBA but im not a quiet pc fanatic, my current rig sounds like a jet plan on load, so these are pretty cheap and I was wondering, If you placed on right next to your NB Heatsink in the first PCI slot, it may actually extract quite a bit of hot air...
  2. capnPedro
    11 Apr 2007
    Can you afford to lose 2 expansions slots though?
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
  4. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    i'd say if you need one of these its a clear indication that airflow in your case is less than great.
    have you looked at the Antec spotcool? similar idea only its a fan on a poseable arm that fits to a screw hole on your mobo. much easier to put the air where you want it an a similar price if i remember rightly.
  5. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Off topic but Overclockers.co.uk vs Overclockers UK?
    Is Overclockers so bad I should spend an extra £20-35?
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    A fan hardly makes a difference as you don't usually have to return them.
  7. wyx087
    15 Aug 2007
    i bought a blower because 8800GTX have vents inside the case, right where a blower's intake would be. it lowered 8800GTX's temperature more than 5c.
    but for current graphics card, which doesn't have any vents inside the case, it's pretty much useless
