Planning The Anti-Mac Planning/concepts- Update 12/11: BOXX for your BOXX
Discussion in 'Modding' started by Roboduck, 8 Jun 2010.
  1. Tangster
    23 May 2009
    With the HDD's there and a lack of cable routing holes, what was the cabling like? Must say having the HDD's there seems like a great idea.
  2. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    It is very clean. Here is the cable management from BOXX. There really isn't much there and its all out of the way. I will clean up the cables more for the Anti-Mac but even stock its very organized.
  3. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Gah - green PCB graphics card....
  4. avolla
    avolla Mini Water Modder
    26 May 2010
    have any new ideas to share with us on the build? any new renders?
    Love that Boxx case. Looks like it's got quite good airflow through it.
  5. Roboduck
    1 Dec 2009
    Haha, yeah i'm not a big fan of the green PCB but that's the only color the Quadro cards come in. ;)
    No new renderings but there will be a few more before the actual build. The BOXX chassis is a bit larger than the Lian-Li PC-7 that I had originally planned on using so the design will change a little bit. I'm not going to give away too much so you will just have to follow the build log :p
  6. avolla
    26 May 2010
    Is that inventor I see running on the screenshot of your desk???
  7. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Looks like it. I've just started using it, very powerfull soft. A friend of mine is student engineer and got me a free educational licence for Inventor :D
  8. Roboduck
    1 Dec 2009
    Nope not Inventor. I use SolidWorks but both are good CAD packages.
  9. GuilleAcoustic
    26 Nov 2010
    The GUI looks the same :D ... well both are from autodesk :hehe:
  10. Roboduck
    1 Dec 2009
    Haha, yeah all the CAD programs are getting more similar with every release. Creo (Pro-Engineer), SolidWorks and Inventor are all moving in the same direction. Soon you won't be able to tell the difference :p
  11. Baguette
    Baguette What's a Dremel?
    6 Aug 2010
    wow, neat renders! I should come to this mod section more often ^^
    For a logo, might I suggest an unbitten apple? Just for the extra "mine has more" feel :p
    BIG fan of the black and orange scheme...
  12. avolla
    26 May 2010
    do you have a file of the front panel with the 2 180mm fans? I'd like to get an idea how you did it. Thanks.
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    had to revisit Roboduck's thread... he actually arriving at Mnpctech tonight, to help me plan an event and mini LAN! :rock:
  14. Guest-23315
    Guest-23315 Guest
    That Boxx case is just about perfect.
  15. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    ignore this post. will post a more revelant in in a few.
  16. siliconfanatic
    10 Sep 2012
    I, personally, would like to see the turbine fans(rev 3) mounted on the mesh(rev 7) with a smaller bezel(or keep em) and mount the fan on the bezel, and the bezel on the mesh. I just wanna see this use a turbine fan because its industrious looking, which is another opposite of a mac if you ask me. And please, don't go 80mm. Looks too tiny to me. I wholeheartedly support any shootoff of mac as long as it screws over daddy jobs. I like the logo, but i also like the bullet-through-the-apple idea. just my $0.02. MOD ON! :D :dremel: :rock:
    edit: Also, i like the idea of making the logo 3d, as apple is sooo 2d. Not completely, but a nice bump, with rounded edges.
  17. sAnity
    sAnity What's a Dremel?
    2 Aug 2012
    This should be fun! subbed!
