The ATI/AMD 64-Bit Shuttle PC by ZapWizard
Discussion in 'Project Logs' started by ZapWizard, 3 Apr 2004.
  1. _rahoul
    _rahoul What's a Dremel?
    5 Apr 2004
    regarding the red anodized Aluminium fans ur using: did you anodize them, or did they come like that. I've never been able to find them in any color besides the plain alu.
  2. tmod
    tmod What's a Dremel?
    9 Apr 2004
    So-Trick Computers :thumb:
  3. _rahoul
    5 Apr 2004
    oooh mama
  4. Spy246
    Spy246 What's a Dremel?
    2 May 2004
    when r u gonna be finishing up this mod. It looks great but is taking soooooooooooooo long to finish.
  5. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    hi zap,
    looking great so far! :thumb:
    Do you have any more pictures of the PSU installed but without the case on? I only ask as im interested in how the 4-cable ATX lead looks when installed compared to a single fat one. Im thinking my psu could do with some re-sleeving! :D
    Thanks in advance,
    RoB
  6. Fly
    Fly inter arma silent leges
    31 Aug 2001
    has you been slashdotted or something, your server is creaking!!! :jawdrop:
  7. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    Christ almighty the mod will be finished when it's finished, you impatient sods! Anyway a tentative deadline of mid July (?) has been mentioned (read the thread).
  8. _rahoul
    5 Apr 2004
    thats coz he's got a job. unlike a lot of people in these forums :duh:
  9. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    As noted, the dead line is the end of this month.
    I can get some more images up later.
    I average 14,000 sessions a week on my website. (20,099 last week)
    It works out to over 1 million hits, and 3+ GigaBytes of bandwidth a month.
    But I am working to slim the bandwidth down some.
  10. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    Get Corsair XMS or AMD to but up a banner on you site you would never have to work again. That amount of hits is incredible.
    I will be glad to see this finished, I bet you are too by now. Going back to the Media PC after this or has another project popped up? Whatever it is I am sure it will be great. Keep up the good work. :rock:
  11. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Sawblade movie?
    When do we get to see a movie showing the sawblade-leds in action? :worried:
  12. ZapWizard
    19 Sep 2002
    The faceplate isn't done at all yet.
    I decided to finish modding the rest of the case and come back to the faceplate last.
  13. MechWarrior
    MechWarrior What's a Dremel?
    13 Oct 2003
    ??? Why is this so far down.... -_-
  14. _rahoul
    5 Apr 2004
    because he hasnt updated it yet :duh:
    what difference does it make if its on page 2? the projects still active....
    :sigh: some people
  15. Nevex
    Nevex What's a Dremel?
    25 May 2004
    Why didnt you fix the messed up cuts on the metal before painting? Is it a look your going for?
  16. ZapWizard
    19 Sep 2002
    There will be trim on the edges, so there is no need to spend time on filling the edges.
    There was a pause for a bit on this PC as I had some other projects at work that needed extra time.
    But I am now back into full-modding mode, and will have some updates soon.
  17. _rahoul
    5 Apr 2004
    you always seem to have "projects".....
    tell us straight, you work for the CIA right? :worried:
  18. MrSaLTy
    MrSaLTy What's a Dremel?
    13 May 2002
    Look at his avatar.... I think its the Secret Service. :D
  19. MechWarrior
    13 Oct 2003
    I appreciate your lack of understanding for a hidden bump in an interesting way in hopes of getting a new status update.
  20. ZapWizard
    19 Sep 2002
    How about some eye candy?
    I have installed the LEDs into the faceplate.
    There are 24 3mm LEDs, 12 Red, and 12 Orange.
    Even under the light of two 12" Cold Cathodes, you can see the glowing red and orange in the faceplate.
    The blade is my temporary plastic blade, the final blade will be alluminum.
    The night shot shows just how bright the LEDs are.
    The light floods out the sides of the faceplate.
    Here you can see the detailed light effect that glows under the plexi.
    With the blade off you can see 24 LEDs, installed at 15 degree angles.
    The LEDs shine inside the the top-layer of plexi, so there is a combined black-mirror (Macroblack effect), and the light effect combined.
    And a night shot with the blade off.
    The LEDs are installed onto the second layer of plexi.
    Here you can also see the cut-out for the slot DVD Drive.
    One the back the LEDs are wired into a ring.
    The contacts were then covered in hot-glue to prevent shifting.
    Unfortunently I do not have the time to create the strobing flame effect I originaly planned on.
