The ATI/AMD 64-Bit Shuttle PC by ZapWizard
Discussion in 'Project Logs' started by ZapWizard, 3 Apr 2004.
  1. Croc
    Croc What's a Dremel?
    4 Jan 2004
    Wow, That looks great. Thats a ton of leds. Do you plan on lighting up the AMD and ATI logos on the front?
  2. y_N_e_M_a
    y_N_e_M_a What's a Dremel?
    16 Mar 2004
    :jawdrop: :jawdrop: :jawdrop: :jawdrop: omg that looks soooooooo nice
    :clap: :clap: great job so far ZapWizard, cant wait to see it all finished :thumb:
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    That is some fine eye candy, Zap :) Too bad you cant do the flame effect. That would have been quite cool. And that LED circuit must have been really annoying to make :lol: I look forward to seeing it all together. Certainly isnt much green on this sucker is there? I take it that the primary sponsor is subsequently ATI. Either way, this is a very fine piece of work indeed, Zapwizard. :thumb:
  4. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    That looks very nice, I aplaud :clap:
    Cheers,
    Mike
  5. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    Amazing. One question, did you plan for the "Zap Wizard" lettering to look "bubbly"? Is that un-intentional, a bad effect in the pic or planned? I think it looks pretty cool...
    L J
  6. piloux
    piloux What's a Dremel?
    12 Nov 2003
    nice front panel :clap:
  7. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    That front panel looks totally professional. Nice lay out, nice laser, nice work!
  8. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I hope to light up the front logo's if possible.
    I will be getting two blades cut, one with just the switch and LED holes.
    And another with cut-outs for the logo's.
    There will be more green then I have done so far.
    The plan is to add some basic light control to allow the light levels to be balanced.
    There are a variety of effects I can do to text, I normaly do a dotted outline around the text, but for this I wanted the text to show up more, so I did a cut about 1/4" deep. The bubbles are a side effect of the laser, but I don't think they look bad.
    Also, the etched text has alluminum tape attached to the back, making the text look silver in daylight.
    Some more updates coming.
  9. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    very nice , i love those colors !! :thumb:
  10. ZapWizard
    19 Sep 2002
    I need some opinions please:
    I broke down and quickly handmade a proto-type blade out of alluminum.
    So I have three options for the front of the case:
    An all-black blade
    My favorite so far, it makes a great contast for the backlighting.
    I may totaly ditch the metal, and make a mirror-black plexi blade.
    A mix of black and red:
    While it looks good, it creates a redundent red-to-black transistion, and almost makes the lights seem non-exisistant.
    Bare alluminum:
    My original plan, but now that I see it, it doesn't quite "fit"
    The button and LED holders don't stand out, and the silver is so light that it makes the lights hard to see.
    /Edit, Changed the black image
  11. RaZoRbLaDe
    RaZoRbLaDe What's a Dremel?
    19 May 2003
    An all black blade, that's my opinion. I like it! :)
  12. alonso_bistro
    19 Feb 2004
    i choose the second option - fit better with the "light system" :)
  13. Malvolio
    Malvolio .
    14 Dec 2003
    Your even questioning this? All black, all the way for the blade. Make it plexi as you've stated, and use a mat black on the back-side of the blade to give a super high gloss effect (and to prevent the paint from chipping off the plexi when people touch the front - which they will).
  14. RotoSequence
    6 Jan 2004
    Hmmmmm... I like the black saw blade quite a bit... But... I have an idea. For a little contrast, why dont you try anodizing the aluminum blade?
  15. Malvolio
    Malvolio .
    14 Dec 2003
    Anodized black? I like that idea as well, so I guess "Seconded". And thusly, I retract my former statement :D
  16. ZapWizard
    19 Sep 2002
    Anodized is another option.
    I will make a mirror-black blade this weekend and see what I think.
    I may stick to the plexi however, as I can make integrated logo's into the paint, and mabye even backlight them.
    /Edit:
    I have edited my post above with this image:
    http://www.zapwizard.com/ATI/Faceplate/black.jpg
    All black metal, without logo's.
    The paint ain't even dry yet.
  17. Spy246
    Spy246 What's a Dremel?
    2 May 2004
    I like the first one it looks incredible. It goes best with your case.
    also when your done with this are u gonna maybe put a x800pro in there and maybe a athlon 64 939 processor. I'm just saying this because won't amd and asus want the newest stuff in this
  18. _rahoul
    _rahoul What's a Dremel?
    5 Apr 2004
    i like the first one too. Is that clear plexi which u've painted, or is it a black piece?
    Maybe you could paint just the back of the clear plexi, then the lights would diffuse and light the logos on the front. I dunno.. :eyebrow:
    edit: oh i didnt see that, its metal. That looks the best, DO IT!
  19. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    Gotta say I like the black and red the best.
  20. Malvolio
    Malvolio .
    14 Dec 2003
    Yes, definately, the more I think/look at the mirror-black metal blade, the better I think it looks. Definately go for it man :thumb:
