The ATI/AMD 64-Bit Shuttle PC by ZapWizard
Discussion in 'Project Logs' started by ZapWizard, 3 Apr 2004.
  1. A ki ra
    A ki ra What's a Dremel?
    20 Mar 2004
    Take it easy with the custom 7-pin jacks. That stuff geting old. Try using a modern techlogy jack? GOD! :grr:
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    There is no exact due date, but it's basicly ASAP
    Easy man,
    The custom jacks on this case were choosen for two reasons:
    1) Durability, normal USB jacks wouldn't last too long, as this PC could be setup and taken down multiple times in a week.
    2) Security, Custom jacks prevent theft as the extra pins can be used for an alarm function, and also theft of any part would require re-wiring for use on a normal PC.
    Multipin jacks are not old technology, they are use heavily in industry for video, audio, and other signals. (The jacks I am using are built for video)
    piloux likes this.
  3. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Jeese, what crawled up his butt? This projects going nicely and the custom jacks add to it, it gives it a look that you wouldn't normally see, so I don't see any problem with them. People need to calm down with their anger, lol
  4. TMM
    TMM Modder
    12 Jan 2004
    :eeek: :jawdrop:
    Thats a crap load of LEDs. Hope you have fun wireing them up :p :D. that looks awsome with two Leds in..... imagine... :eeek: :blush:
    did you do anything to the plastic (sand etc) to get that streaky effect, or was that how it just came out?
  5. ZapWizard
    19 Sep 2002
    Wiring the LEDs will be a challange for sure.
    I did nothing to the plastic to get that effect, the mirror like cuts from the laser cutter make the edges create that effect.
    The hard part is getting that effect without using a white background.
    (As in the image)
    I need the same effect on a black background to match the PC.
  6. piloux
    piloux What's a Dremel?
    12 Nov 2003
    The front panel lightning is going to be awesome :jawdrop: :clap: your project is giving me ideas :thumb:
    can't wait to see next update :)
  7. A ki ra
    20 Mar 2004
    I'm not angry or whatever. I'm just annoyed that he still using the simular plug from his Ammo case thats posted everywhere:yawn: I just think it boring thats all then again theres alot stuff thats boring to me espcally windowed case and all the lights. Theres nothing new about it nearly everybody does it.
    Anyway good luck on your project.
  8. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Does the outside of the laser cut parts really have that clear of a finish?
    I am having some parts done for me for project baby bliss and I hope they come out that good. By the way awsome design on the blades with the lighting, theyreally do look professonal.. :clap:
    Whay did you use laser cutter wise to do them, the versa laser?
  9. ZapWizard
    19 Sep 2002
    Yes, the laser cuts a near perfectly smooth edge, and yes it was done on a versalaser.
  10. r3Q
    r3Q Minimodder
    31 Jul 2002
    that was a great idea to implement the LED holes directly in the CAD drawing... are you planning on putting some kind of shroud on the front to block all the LEDs from view? i think that would look crappy if ya didnt =p im sure you have somthing in mind.
    i just want to see what kind of hardware its gonna have.
    well. this is gonna be a kickass mod. =) zap- you are the freaking man.
  11. ZapWizard
    19 Sep 2002
    Those LEDs will be directly below a brushed alluminum blade on the front.
  12. Boggy
    Boggy What's a Dremel?
    3 Jan 2002
    Great to see you are keeping up the standard Zap ;) Nice one again
  13. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Thanks for the reply, I am looking forward to getting my peices back... thanks
  14. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    This machine is gonna kick @$$!! :rock:
    KEEP IT UP! :rock:
    Cheers,
    Mike
  15. ZapWizard
    19 Sep 2002
    Ready for some more?
    I have completed the UFO glow effect for the PC.
    Under the case, and centered on the bottom is a 9cm acrylic puck that contains twelve ultrabright 5mm Green LEDs.
    You can also see the case feet are now installed.
    This close-up shows the LEDs, resistors and the two existing holes on the case I will use for mounting.
    (They are the screw holes for mounting a 4-point heatsink)
    The holes are off-center but the puck is not.
    More images here:
    http://www.ZapWizard.com/ATI/UFO
  16. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    understatment of the century? i think so
    holy cow, that's bright, and looks really good.
    /me needs to be able to solder like that
    keep it comin zap, it just keeps getting better (though i still don't think you can top the ammo box lan pc :p )
  17. Langer
    Langer Jesse Lang
    24 Jan 2004
    Can you wait a little while longer...I wasn't ready for more.
  18. tortuegeniale
    tortuegeniale What's a Dremel?
    7 Nov 2003
    Perfect job ! :thumb:
    are the leds glued to the plexy ?
  19. ZapWizard
    19 Sep 2002
    The LEDs push fit into the plexi.
    I then filled in the pin-area with hot-glue.
    The LEDs are so bright, I have decided to add a light controller to allow the different effects to be turned up, or down.
  20. opus13
    opus13 What's a Dremel?
    11 Oct 2003
    are you going to diffuse the glow a bit, or do you aim to ruin the eyes of ati employees around teh globe?
