Case Mod - In Progress The Avengers Level 10 project
Discussion in 'Project Logs' started by BLUEHORSESTUDIOS, 30 May 2013.
  1. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    Project sponsored by Thermaltake
    I was excited when Thermaltake came knocking asking if we can mod their Level 10 limited addition into into the Avengers for the release of the new Iron Man movie and Computex .
    We discussed concept ideas and with a solid design plan we began to assembled the Avengers team.
    With the case on the bench,I begin to the disassembly process,
    parts labeling and packaging
    Now with the case completely disassemble, parts labeld and packaged up,Ill start on the first elements of the build..The Captain America optical drive cage.
    I used 00.80 styrene to cut,form and heat shape the ammo pouches,belt,harness,map pouch and star.
    I used a dremel with a small engraving bit to simulate the leather stitching in the plastic.Once its painted it should look like real leather.
    [​IMG][/URL][/IMG]
    With all the rough work done, I can do some mock-up on the panels.
    Time for paint and graphics
    With the optical drive bay completed, I want to start masking up the case body and prep it for paint.
    The plan here is to create riveted panels and a two-tone paint scheme. I first applied these small adhesive pearls that will look like rivet heads once the paint is applied,sprayed a metallic charcoal then my detail tape lines. The rivets will be finished with a titanium dry brush effect later in the paint process and the clear coat will seal the firmly to the case body.
    Time to apply the same paint scheme to the hard drive bays,6 total and a million screws.
    The vinyl letters will create my paint mask and once removed the metallic undercoat will be revealed.
    Up next is the S.H.I.E.L.D PSU cage
    I want to create a illuminated sign that will be attached to the cage door.First I print out the image and transfer it to my styrene.
    Next I begin cutting out and sanding down all the pieces.
    Paint in a gradient effect is applied next.
    I adhere the logo to a thin piece of smoke black transparent acrylic
    Same paint process will be applied here as the case body.
    Time for side case door panel.
    Thermaltake requested the Mark XLII Iron Man Chest Plate for this locating. Will Do Sir!!
    The following pics show the entire process from templates design,constructing and paint.
    The first thing to be constructed is the Arc Reactor
    Gary Lee, Thermaltakes Market Rep requested one for himself so I made two.
    Up next..the under armor and mesh.
    I used the same styrene material,heat form and shaped in this process.
    In this pic I cut the template into some bristol board and do some mock-ups. Tho this piece is static, I want to have it function like the real Mark XLII suit,opening at the lower chest area revealing the Arc Reactor.
    In these few shots final paint is applied to the Mark XLII chest piece and mounted to the door.
    In this shot, most the panels have been mounted,Thors Hammer constructed and mounted to the case door.
    Thermaltake requested this be shipped without a system installed so I apologize for no sexy pics of the hardware we all love.
    Heres the final studio shots
    Thanks for viewing
    Stay Inspired and Keep Creating!!​
    Waynio likes this.
  2. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    THATS EPIC!!!
    5stars from me!
  3. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Awesome!
  4. BLUEHORSESTUDIOS
    19 Apr 2010
    Thx guys,appreciate the kind words
  5. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    OMG!! This is fantastic!:jawdrop:
  6. almamater
    almamater What's a Dremel?
    25 Apr 2009
    OMFG!! :jawdrop: :jawdrop:
  7. MADKiller7
    MADKiller7 What's a Dremel?
    28 May 2005
    Speechless.......
    The mini ARC reactor :eeek: :jawdrop:
  8. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks Madkiller,it was a fun project.
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    The styrene pouches armour & straps, they look so real, superb model crafting & airbrush detailing. :jawdrop:
    This is so well up with the best mods I have seen & all in a quick fix, amazing quality, awesome modding highlight of my day, appreciated. :)
    Thought maybe you wasn't doing the avengers one but then out of the blue here it is completed. :clap:
  10. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    I saw a picture of this on facebook and at the time i thought it looked awful, like someone had bought some kids avenger bits and stuck them on a case. Oh dear lord was i wrong! Those pictures did not do this any justice what so ever. The the attention to detail is just incredible. I shall go and wash my mouth out with bleach for uttering such nonsense.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
  12. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Holy sh**e WOW what a beautiful piece of art.
  13. Evenge
    Evenge Minimodder
    16 Sep 2006
    :rock: Awesome work!
  14. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Outstanding.
  15. TadZilla
    TadZilla tadbitnerdy
    5 Nov 2009
    Ladies and gentlemen... THIS is talent... Awesome job.
  16. Parge
    16 Jul 2010
    Errrrr. Ridiculous talent!
  17. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks Man ,Im excited to be done hand shipped of to Computex
  18. BLUEHORSESTUDIOS
    19 Apr 2010
    No worries Man, Thanks for taking a second look and commenting.
  19. BLUEHORSESTUDIOS
    19 Apr 2010
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    My sister is big fan of Avengers,and she said me to wrote that this project is apsolutely amazing. :)
    I share her opinion.
