Graphics The BEST GTX 780 for £400 (or less)
Discussion in 'Hardware' started by pete*, 20 Feb 2014.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    Hey all,
    Really I want a list of all the GTX 780's there are, listing their performance
    etc. (I've been looking and I keep getting german language sites!??!)
    I'm trying to find one for at the MAXIMUM £400 thinking there would be
    only a couple. But turns out there is quite a few, but that just confuses me
    a lot! Which is the best one currently to get or is it really neither here nor
    there? I want good cooling and preferably on the quieter side.
    Also warranty is kind of important.
    Thanks in advance peeps! :)
    Pete
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    The Gigabyte GTX 780 typically leads the pack from the various reviews I've read...
    Personally I'd be swayed by the EVGA ACX GTX 780...
  3. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    The only real difference between most of the GTX 780 variations is the overclocking some have and the different coolers and number of fans, there is no real big performance difference that I can see, I bought the 3GB MSI GTX 780 Twin Frozr OC and it's an excellent card and quiet for £390.
    Some models that cost near £500 are just not worth it (not including the hydro copper models) your paying for the name they all have 3GB vram and 2304 cores.
    You can see most models and specs here.
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
  6. Parge
    16 Jul 2010
    That Gigabyte card looks badass!
  7. pete*
    29 Apr 2009
    Yeah I've been looking at the SC ACX. Looks nice.
    Just need to find a decent case to replace my ps07
    now. :)
    And a good closed loop CPU cooler.
  8. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    You have a similar system to mine, I've just built a 4770k, that sc acx 780 in a corsair 350d case. Using my old h100 cooler, the pc is silent i love it !
  9. pete*
    29 Apr 2009
    Isn't it a tight fit in the 350D?
    You see I love the Air 540(think 540..) but it has
    no space for HDDs!! So annoying!
    The 350d is nice but I'm looking for a slightly bigger
    case. I just want more space within the PC (with ATX compatibility).
    Fractal designs don't do good enough cooling of gpu for
    my liking.
  10. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I only have 1 ssd and one hdd in my case, rest of them are in the server downstairs. I don't think you could go wrong with any of the 780 cards, they are beasts.
  11. Guest-16
    Guest-16 Guest
    ADD MOAR FANS!
    That EVGA and ASUS DCII will be quieter and certainly comparative. Pick out some reviews! :)
  12. Shirty
    18 Apr 1982
    I feel like none of those choices will disappoint you :)
  13. GeorgeStorm
    16 Dec 2008
    I'm personally a fan of the Gigabyte card, but as others have said you can't really go wrong with any of the 780s, they're pretty epic cards.
  14. urobulos
    urobulos Minimodder
    13 Apr 2010
    I'm not sure how set you are on the Green team, but recently on Scan, the MSI 290 has been cut from 370 quid (too expensive, too close to 780 price) to 330 quid. That's pretty much MSRP of the stock card, but with a mere 10 quid premium for a very good cooler and a solid overclock. The 290 is more or less equal to the 780, some games AMD is a bit faster, others go to Nvidia
    If AMD is a no no, then the least I can say is that the MSI Twin Frozr cooler on my 290 is very quiet and does a sterling job of keeping that toasty Hawaii CPU nice and cool. Looks like they are using the same design on the 780, so if you want a (relatively) cheap OC'd 780 with a good open air cooler, then the MSI cards should do you fine. If blower is preferred, then you really only have EVGA under 400 quid on Scan, so the choice is made for you.
  15. pete*
    29 Apr 2009
    Pretty much hooked on the SC ACX.
    And yeah urobulos, i'm team green. :p I had stability issues with the 4*** series of Radeons
    quite a bit, and couldn't be bothered anymore.
    Green has been rock solid for me. Also, current AMD run very hot on air, so a big no no for me
    at this point. :] Until watercooling that is... xD
    Thanks all for the help. :)
  16. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Great card, same as me you won't be disappointed at all.
  17. Hamfunk
    Hamfunk I AM KROGAN!
    10 Nov 2009
    Zotac 780 AMP!
    54 pence over, but by far the best pre-overclocked card for the price. Also comes with a 5 year warranty!
    I'm sure you'll enjoy the EVGA though if thats what you went for. :thumb:
  18. Parge
    16 Jul 2010
    I have the 670 version of this, and it is THE best overclocking anything I've ever owned!
