The best heat Dissipating material (real one)
Discussion in 'Hardware' started by xrain, 23 Feb 2004.
Best heat Dissipating material
  1. platinum
    11 vote(s)
    7.7%
  2. gold
    21 vote(s)
    14.8%
  3. silver
    43 vote(s)
    30.3%
  4. copper
    21 vote(s)
    14.8%
  5. glass
    2 vote(s)
    1.4%
  6. other material
    47 vote(s)
    33.1%
  7. no idea what so ever
    12 vote(s)
    8.5%
Multiple votes are allowed.
  1. xrain
    xrain Minimodder
    26 Jan 2004
    sorry i forgot to put a poll with the last thread :wallbash: :duh:
    think about the heat Dissipating proporties not the cost
  2. TMM
    TMM Modder
    12 Jan 2004
    I would have thought gold or silver, but punched in copper before i could think LOL
  3. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    From what I have heard, silver beats copper slightly, and copper beats gold easily. But reports have said that properly formed diamonds transfer heat FAR better than even silver.
  4. Darv
    Darv Bling!!
    12 Aug 2002
    Yer, diamonds will transfer heat much better than most other materials. But people don't make heatsinks/waterblocks out of diamond for obvious reasons
  5. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    I'm sorry, but I think you need to clarify a little.
    What exactly do you mean by heat dissipating properties.
    If you mean which is the best material to use in a waterblock, then the only thing we are interested in is thermal conductivity, since the mechanism by which thermal energy is dissipated into the water is largely independent of the material of the water block.
    In which case, diamond is just about the best thermal conductor. Pyrolytic graphite has incredible thermal conductivity in the basal plane but is anisotropic and has very poor conductivity in the third axis, hence it is not suitable for waterblock construction.
    Both of the above are ludicrously expensive.
    A number of companies have developed "diamond composites" with an effective thermal conductivity somewhere in the region of 50-100% increase over copper, at up to 800W/m/K.
    With regards to metals,
    Silver is around 430W/m/k
    Copper is around 400W/m/k
    Gold is quite a bit lower, can't remember off the top of my head.
    Aluminium is slightly lower than gold and brass is a little lower than aluminium.
    However, if on the other hand, you are talking about the materials ability to radiate heat, though I'm not sure why you would be since this is almost entirely irrelevent unless you are in space, then aluminium would be a good choice.
    So there you have it.
    Silver is the best material for water block construction, though it is very expensive. It has a greater thermal conductivity than copper and is much easier to machine.
    Gold is pointless, so don't ever suggest it.
    Aluminium is a cheap, free machining material, making it ideal for the design of prototypes, but problems with galvanic corrosion should discourage you from using aluminium as a long term material, particularly in a loop with copper/brass heatercores/rads.
    I have not taken part in the poll simply because the question is too ambiguous.
    8-ball
  6. 8-BALL
    6 Nov 2001
    Ok here they are.
    Platinum 71.6
    Gold 317
    Silver 429
    Copper 401
    Aluminium 237
    I added aluminium since you clearly forgot this.
    Platinum is crap.
    Units are in W/m/K
    8-ball
  7. KryoNexus
    KryoNexus What's a Dremel?
    21 Jan 2004
    ::dreams of a diamond heatsink::
    personally, i think copper is the best if you are going for performance vs cost effectiveness, but i would love to throw a silver waterblock into my system :)
  8. Guest-16
    Guest-16 Guest
    Tbh its something id like todo is make a diamond base for a heatsink. It is possible with CVD techniques but would take FOREVER to make one that big, reguardless of energy cost.
    A sterling silver one would be nice mind. Wouldnt mind trying an osmium alloy one, its the densest metal known so should provide good transmission of heat although it smells badly it says here <reads periodic table>.
    Dissipation is different from conduction though, hence why platinum has good conduction but crap dissipation?
  9. 8-BALL
    6 Nov 2001
    The figures I gave WERE for thermal conductivity.
    Platinum is crap.
  10. 8-BALL
    6 Nov 2001
    Oh, and osmium only has a conductivity of 88W/m/k
  11. 1398342003
    2 Sep 2002
    The best use of a diamond in a WB would be as a circular base with cups for the cascade.
  12. 8-BALL
    6 Nov 2001
    Yes it would, but we a re reaching a point where there is little to be gained in water block technology itself.
    The interface between the core/IHS and the base of the water block is becoming more and more significant, and is the key area to dropping cpu temps without active cooling.
    8-ball
  13. xrain
    xrain Minimodder
    26 Jan 2004
    Thanx 8-ball you answered my question even befor i asked it :D , about the "i messed up on last thread thing" i was trying to make this post except i forgot to make a poll :duh o well.
    i looked at the current silver price and its a little more than $6 per troy ounce. so i just might make a silver heat sink in the near future.
    ps. apologys obout for getting aluminum and dimond i just wasnt thinking about them or there woulda been alot more choices. thanks for takeing time to pratisapate in my poll i was just curios about it (personally i thought gold was the best :lol: ) o well shows what i know :p
    --xrain--
  14. ////\oo/\\\\
    ////\oo/\\\\ Minimodder
    16 Oct 2003
    It has been posted several times before, though I don't remember seeing the bit about them doing a TIM
    Copper Diamond Alloy
    DiaCU-II 1200 W/m/K :eeek:
  15. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    instead of using natural diamonds then cutting them for use in a waterblock, how about synthetic diamonds. of course cheaper than natural diamonds but still would cost an arm and a leg for that size crystal! :waah:
  16. dudeyourmomiscute!
    dudeyourmomiscute! What's a Dremel?
    14 Dec 2003
    the best would be a diamond heatsync.
  17. ////\oo/\\\\
    16 Oct 2003
    But hardly possible, imagine trying to chisel facets to make all the channels, it would be a total nightmare :nono:
    Incidently I just read the thread title again
    Did you expect anybody to invent one?
    I know of this wonderful material, perfect for heatsinks:
    Splurgurgium 57,924 W/m/K
    :lol: :lol:
  18. 1398342003
    2 Sep 2002
    Well in theory, not reality, one could produce many different magical metals that wisked away the heat. Much like splurgurgium, a naturally occuring gas. Unfortunatly in it's gaseous state it's heat transfer capabilities are terrible. :lol:
  19. friskies
    friskies What's a Dremel?
    17 Nov 2003
    I read about this company in taiwan (I think), who are claiming to have developed the processortechnology for the future.
    They have developed a diamond-circuit which runs at 81 GIGAHERTZ :D No bull!
  20. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    Why you raving about dimond? Carbon Nanotubes are better. And Friskies Dimonds are being prepared to roll out for use in radars
