Hardware The best way to clean your keyboard
Discussion in 'Article Discussion' started by Sifter3000, 5 Jul 2009.
  1. stoff3r
    stoff3r What's a Dremel?
    20 Nov 2006
  2. Valdisnei
    Valdisnei Can i haz a dremelz!?
    22 Sep 2007
  3. Horizon
    Horizon Dremel Worthy
    30 May 2008
    *Raises hand* umm this is my keyboard
    I'd like to stick it in the dishwasher, there's a distinct crunch when i hit certain keys, but at the same time I'm just very very afraid of the worst case scenario
  4. quack
    quack Minimodder
    6 Mar 2002
    I have some Cyber Clean. It's awesome, I let my girlfriend loose with it on her keyboard today and she was impressed with the results, and it was a pretty manky keyboard!
  5. The boy 4rm oz
    10 Apr 2008
    My keyboard has never gotten that bad before, ever, I hardly get any grime on mine. I give my keyboard a good blow out with the air compressor every now and then to get the dust and crumbs and such out of it, then I wipe it down with a damp cloth, works great.
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    instead of buying 10 pounds of cleaning stuff and take a few hours of your time to clean the keyboard. Buy a new one for around 12 pounds. Unless you have some kind of fancy gaming keyboard...
  7. JoHoschi
    JoHoschi What's that?
    5 Oct 2006
  8. Primoz
    Primoz What's a Dremel?
    22 Dec 2007
    What do you do if the keyboard doesn't disassemble so you can't wash it? I used to 'explode my old keyboard and wash it, but this Lotitech Ultra Flat only goes down to the keyxs' rim being removed.
  9. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    I have the G11 ( i know, i know...) And I remove the keys with a jewelers screwdriver, pop the keys in some water or if they're really bad, water with alka seltzer, and use baby wipes on the rest. Works really good. Glasses Cleaner works good too.
  10. B3CK
    B3CK Minimodder
    14 Jun 2004
    I would be careful about using dish detergents in with your electronics. Alot of them can etch your pieces as they are designed for tougher materials ie. glass, metal. Also some of them contain alot of phosphates.
    On the same note, especially if it is an older dish-washer, you can get away without using any cleaner as there is usually alot of buildup inside your machine already. Try the first wash without the cleaner, see if it works. If not, you lost <1hr; simply do it again with a cleaner if you want.
    I use clorox wipes about once every other month, and everclear, (95% grain alcohol) every other year or so.
  11. jamesthebard
    jamesthebard Too Much Time On My Hands
    2 Jan 2009
    It all depends on the keyboard and your threshold for pain. I'm working off a Unicomp keyboard. The plus side is that each key has a 'cap' that can be easily removed and cleaned. The downside is that you have to remove each 'cap' to clean it. A washcloth, some Windex/cleaner, and a bit of time and the keyboard is as good as new.
  12. jhbellsh
    jhbellsh Hmmm... never mind.
    23 Jun 2009
    A quick warning: Don't use hair driers on anything other than the coolest setting and from a bit of a distance... I once had a student at the Uni I used to work at come to me with a melted laptop keyboard - asking if I could help... well, yeah, don't use a hot hair drier! Muppet!
  13. GoodBytes
    20 Jan 2007
    Well it depends on the power of the hair dryer. The expensive one yea, the ones you find at the local or small pharmacy... not so much.
  14. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Well I finally took the step to clean my keyboard also. Took it apart, went to the window, and blew a part out :wallbash: Took me 20 minutes to find it in our garden, after I found out that I really needed the rubber spring under the space bar :eyebrow:
  15. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Not to mention that bacterias get more resistant to those anti-bacterial products, making them harder to kill.
    I usually clean my keyboard with a cloth and alcohol.
  16. an4rew
    an4rew System Builder
    5 Jul 2009
    I use the vacuum cleaner for crumbs.
  17. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Off with the electronics, out in the garden.
    3/4 inch stiff bristled paint brush and a hose with a jet setting on the nozzle. I don't care that much about bacteria, so probably not the 'cleanest' way, but a hell of a lot of fun, for cleaning a keyboard.
    My uncle has (or had?) this funky foam stuff. Whip the keys off, stick 'em in a jam jar or something (about a third of the keys at a time), spray the foam in, shake like you're having a seizure in your arm, rinse and repeat. They got very clean very quickly.
  18. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Thanks for confirming the Tesco offer is still going. Sure the pressure's no great shakes but if you can afford two of them who cares - they did both my PCs inside and out and both my keyboards before running out - for 8 quid, bargain.
    In case I get bored of recycling aerosol cans, what's the going rate of an air compressor with tank? Is that something Maplins would have?
  19. Spode
    Spode What's a Spode?
    9 Jan 2004
    Annoyingly/ironically - only a few days after writing this feature, I spilled milk and cereal all over my keyboard - my nice shiny new Microsoft 6000 Wireless.
    I immediately turned it upside down and whipped the batteries out. I then took the shower head and while it was still upside down, I hosed it down (milk smells naaaassty when it goes off). Still upside down, I dried it off with a towel and then blasted it with the hair drier for a little bit. Then I left it over night, still upside down, to dry.
    I kept it upside down so none of the fluids could penetrate into the electronics. Put the batteries back in this morning and it's, well, just lovely!
  20. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Actually, now I'm in the market for a new keyboard, but I prefer heavy travel to the point of microswitching, as I learned to type on a really heavy typewriter. Argos sells keyboards like this for only a fiver (the ones that look like they're rebranded by Dell) but you have to keep the room dust free otherwise it'll help take the labelling off the keys over time.
    So if anyone knows of a wired, PS/2 keyboard with keys raised at standard to high profile, that you can strike hard and get a solid response back, let me know, at the moment happy to go up to 20 quid. If it has to be USB then I can live with that.
    Otherwise I'll just buy a plastic dust cover at the same time as the new Argos one, and vacuum my lounge twice a week...
Tags: Add Tags
