Fenrir still looks awesome in metallic red though! @ Pookeyhead : Those two fans don't look like enough cooling for me. If there is room in the roof, atleast one 120mm put there would do the world of good for cooling.
Then you're be wrong OCed to 3.8GHz... can constantly run Linpack at 100% on all cores for 24/7 @ 69 degrees or less (and that was in summer with a 27 degree ambient) At stock speeds it never gets above 45 degrees flat out). If I want better, I'd have to water cool it. It's not the amount of fans that matters. Too many can cause undesirable negative or positive pressures inside the case. It's more beneficial to have one, free flowing path rather than have many exit points.
Thanks for putting up with such ridiculous newbie questions guys. My first machine is put together and is having Windows 7 installed on it as I type. Thanks again!
