hi...this is going to be my first projectand its called chilled Pc the whole idea is to make a pc that will be cooled from a varius of fans. the cooling system for the cpu will be this fanduct: http://www.sunbeamtech.com/PRODUCTS/OVERCLOCKERS COOL KIT.HTML with the silver kit the whole idea is to cool the pc down so much that i can overclock much, and also get a cooled down system so i wont get an unstabel system that lags. and this fan will help cooling down the pc by sucking out the heat from the mainboard...and graphic card http://www.mamut.com/homepages/Norway/1/5/3dfxcool/52.jpg updates on their way
With various fans (blowers like these includes) you get "some" noise. Mmmm... if it doesn`t matter, go ahead, but you can minimize the noise a little. Well, the faduct its a good idea. Try to duct other parts (like GPU or NB) to use the minimum amount of fans and save space to cooling.
why not have the whole case made of 80mm or 120mm fans, glued/bolted together, then have plexiglass windtunnels so the air gets where it needs to be. Of course this will involve lot-o-plexi bending with hot air gun.
yeah....i start ducting my cpu towmorrow...i guess...and ill probably find something to cool down my grapgics card too
