Modding The Core (a.k.a. my gaming rig)
Discussion in 'Modding' started by simon_C, 1 Apr 2006.
  1. simon_C
    simon_C Minimodder
    13 Nov 2005
    just thought i's post some pics and specs of my modded rig.
    heres a "before" pic:
    i have since removed the temp sensors until i get new ones. i broke the old ones.
    PROC: AMD Athlon 64 3000+ socket 939
    RAM: OCZ Premier Series 1gb (2x 512) ddr400
    VIDEO: eVGA GeForce 7600GT 256mb PCI-E
    HDD: Hitachi Deskstar SATA][ 80gb
    PSU: Fortron Source Group 500w BlueStorm
    CASE: Modified Beantech Igloo 1
    CPU HSF: Zalman 7000Cu
    OPTICAL 1: Lite-On DVD/CDRW
    OPTICAL 2: H/P CDRW
    FAN CONTROLLER: Vantec Nexus with CCFL controller
    FANS: Silverstone 80mm Whit 76cfm
    1394: Generic pci card
    Opinions?
  2. Shpoon
    Shpoon What's a Dremel?
    12 Jan 2006
    And the specs?
  3. simon_C
    simon_C Minimodder
    13 Nov 2005
    edited them in
    so what do you think?
    i did the window and the front grille. simple i know but still, i had a good time with it.
  4. onggie
    onggie What's a Dremel?
    12 Jul 2005
    What cathodes did you use? I am trying to get that kind of orange but all I can seem to get is damn pink!
  5. simon_C
    simon_C Minimodder
    13 Nov 2005
    its actually not orange. its very bright red. my camera makes bright red look washed out and orange. they are logisys brand.
  6. simon_C
    simon_C Minimodder
    13 Nov 2005
    Grr.... fan controller crapped the bed. ordered a replacement along with a temperature display. should be here tomorrow ill get a pic then
  7. Arkuden
    Arkuden mow?
    9 Jul 2004
    That doesnt sound right. AFAIK XP's were mostly Socket A, and then replaced by semprons which you can get to Socket 754...unless you mean Athlon 64 maybe?
    Looks good though, nice cuts
  8. simon_C
    simon_C Minimodder
    13 Nov 2005
    thanks, and yeah, i meant 64. XP is force of habit.....used to seeing it on the archives on the old modding sites i research on...
    yeah the cuts were doen with a 4" angle grinder, a dremel, a flat file, and a jeweller's file. the cutting took no time, its the filing that took ages to do. but in the end i'm happy with it.
    EDIT: i cant believe they bleep ba*tard file..... changed it to flat
  9. DougEdey
    5 Jul 2005
    Athlon 64's were on s754 originally, they were renamed to Sempron when they removed the 940th pin off the 940 to make them to 939 (I know this since my CPU doesn't say Sempron anywhere on one system, but has Sempron on the other one, both are 754
  10. simon_C
    simon_C Minimodder
    13 Nov 2005
    sempron and athlon are totally different cores. the sempron was the economical amd processor and the athlon the standard model.. and socket 940 came after 939.....
  11. DougEdey
    5 Jul 2005
  12. simon_C
    simon_C Minimodder
    13 Nov 2005
    really? hmm.... anyways...
    im happily overclocked now at 2528mhz from 1813mhz... whee go me... and my 7600 is running at 620mhz from 580mhz. things are running a tad more smoothly now. gonna see my results in the CS:S stress test.
    meanwhile, some updated pics... i have since added handles to make lugging this thing around easier. and my new fan controller and temp/fan rpm display came in. bit of a hodged color scheme but what the heck.
    im out!
  13. windwakerfan
    windwakerfan Banned
    5 Jan 2006
  14. simon_C
    simon_C Minimodder
    13 Nov 2005
    small update:
    running smooth now at 2661mhz. gonna leave it there. running mid 30s for temp at idle. seems to be going smoothly!
    by the way, anyone have any ideas for this thing? im looking for a little more to do to it....not entirely sure what yet. i'd do a top window.... but theres nothing to see. hmmmmm....
    later
  15. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    That Beantech is a rip from Lian Li's PC60...
  16. Elias
    Elias What's a Dremel?
    10 Apr 2006
    My Gaming RIg NO PICS :(
    This is the gaming RIg i built like a month ago, but i should have waited for the 7900gtx's it's ok though, ill live :D :read: :thumb:
  17. Mister_Tad
    27 Dec 2002
    That is what you call thread hijacking
    For the love of god man, think before you click reply or you will be finding your stay here chopped incredibly short
  18. simon_C
    simon_C Minimodder
    13 Nov 2005
    hah i know....bit its half the price! and all the quality is there too.
