Scratch Build – In Progress The Delta
Discussion in 'Project Logs' started by nhenhophach, 26 Nov 2016.
  1. nhenhophach
    nhenhophach Bit-tech
    16 Aug 2007
    Hello everybody!
    My scratch build is a triangle case that you can see all hardwares and flow and dust will not touch direct Motherboard, RAM, VGA...
    I used Aluminium profile and 6061 plate to do the chassic. And it can turn left, right 270 Degree
    Design
    After CNC Cut
    Motherboard Tray
    Aliminium Profile
  2. nhenhophach
    16 Aug 2007
    After anodizing and add ball bearing
    Time to making Module Rad and Pump.
    First i wanna paint the Aquacomputer Radiator's cover
    Finished
  3. nhenhophach
    16 Aug 2007
    Still using my invention from 2010 The Interconnected Plate to do this Mod
  4. nhenhophach
    16 Aug 2007
    Prepare ASUS RAMPAGE V Extreme with EK Monoblock
    Install parts
    Li-Heat PCi-E Riser 20cm
    Reservoir Cover
    I will not focus how to install the hardwares, just make it cool.
    This case i show at Intel's Event so i finish with Red pattern
    To be continude
    Thanks for watching
    nhenhophach
  5. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Amazing, beautiful design, well done!
  6. Cheapskate
    13 May 2007
    :thumb: I love your work.
  7. amagriva
    amagriva Minimodder
    13 Jun 2009
    Soooo good! Bravissimo :clap::clap::clap:
  8. Vault-Tec
    30 Aug 2015
    At first I thought "aww it's all diddy !" then you fitted the board and I was all like :eeek:
    Great work man :rock:
  9. nhenhophach
    16 Aug 2007
    Finished
    Some pics of The Delta with old Pattern
  10. nhenhophach
    16 Aug 2007
    ASUS ROG 10th Aniversary
    This version for ASUS ROG 10th Aniversary
    Specs:
    Mainboard: ASUS Rampage V Edition 10
    CPU: I7-6850K
    RAM: KlEVV 32G
    ASUS GTX 1080 Founder Edition
    SSD: Plextor M8Pe 512G
    PSU: Inwin Classic Series 750W
    Watercooling parts: Bitspower International Co., Ltd.
    PIC-E Riser 立熱工業 Li-Heat Industry Co.,Ltd.
    Thanks to all.
  11. AM Modding
    AM Modding What's a Dremel?
    11 May 2016
    The only thing i don´t like is the sticker of the psu
  12. nhenhophach
    16 Aug 2007
    Thank you
  13. amagriva
    amagriva Minimodder
    13 Jun 2009
    me too...
  14. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    and me :hip:
    Great work, awesome build.
  15. Cheapskate
    13 May 2007
    AWESOME! :D
    Did you build 2 cases? Or refit the 1st one for the ROG event?
  16. nhenhophach
    16 Aug 2007
    Actually 4 case, bro:D
