The difference of VENICE / WINCHESTER core?
Discussion in 'Hardware' started by philb, 30 Jul 2005.
  1. philb
    philb What's a Dremel?
    2 Jan 2004
    Is there any significant differences between the two?
    Also any advice on a motherboard, looking for NF4 probably, or nf3, but not to intersted in SLi!!
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Venice is a 90nm core with SSE 3 instruction sets and an improved memory controller. Since prices are essentially the same, you want the Venice. There are plenty of Nforce 4 boards out there that arent equipped with SLI; DFI's Nforce 4 Ultra based board isnt very expensive, and overclocks like crazy. Or, you could be cheap and go with one of the less expensive ones out there.
  3. webbyman
    webbyman Hax.
    7 Oct 2004
    yea what he said and winne's are also 90nm but can't support 4 dimms at ddr400
    also they only have sse2 and venices clock a tiny bit better.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Both 90nm, Venice is based on the E3 core revision, with a slightly improved memory controller, and SSE3 support.
    Get the venice over winnie any day :)
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    And don't forget the "extra layers of copper interconnects" in Venice - that was the difference between Tbred A and B, and look how much that helped ;)
