The DS USB dongle just a regular WiFi dongle?
Discussion in 'Gaming' started by Veles, 10 Feb 2007.
  1. Veles
    Veles DUR HUR
    18 Nov 2005
    Want to connect my DS to the tinerweb, and was just wondering if this (http://www.play.com/Games/DS/4-/731691/Nintendo_DS_Wi_Fi_USB_Connector/Product.html) is just a regular WiFi dongle but with Nintendo slapped on it? I'm guessing it probably is, you connect your DS via WiFi to your PC, and then you can copnnect it to the internet through this connection.
    I'm doing something similar to this already with my 360, although it's connected to my PC by an ethernet cable instead of wireless. So am I right in thinking a wireless dongle/PCI card would basically turn my PC into a wireless access point, albeit with a very bad range? So this would also work with a Wii, a laptop, well, any wifi device really?
    Cheers for any help.
  2. DougEdey
    5 Jul 2005
    It's a buffalo powered unit, but all the encryption is performed by the software.
    There's no way AFAIK to connect a non-nintendo device to it, my Wii worked with mine, but then I just bought a new router for £40.
  3. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    there are some that can work, but you have to write your own drivers, there are guides on the web.
    A company makes one that works with DS and PSP for £15 tho, i think its called wifiMax
  4. DougEdey
    5 Jul 2005
    The WiFi max IS a standard WiFI dongle, it is designed to work as an AP.
