Case Mod - In Progress [The Duality] [Dual System, Godavari & Skylake in a Frozen-Q Apex mATX]
Discussion in 'Project Logs' started by Duality92, 9 Jun 2016.
  1. GeorgeK
    18 Sep 2010
    To OP: You can change the thread title by clicking edit on your first post and then 'go advanced'
  2. Duality92
    Duality92 Member
    25 Feb 2015
    One of two radiators done!
  3. Duality92
    Duality92 Member
    25 Feb 2015
    I've been in great discussions with Frozen Q about the custom Apex mATX case. It seems that putting two full ITX systems and a full custom watercooling loop into an mATX chassis isn't the easiest task, who would've thought? ;)
    That means,
    • Two ITX boards (One with a big GPU)
    • Two ATX Power Supplies
    • Two 280mm Radiators
    • Two (actually three) SSDs
    • etc etc. I think you get where I'm going with this ;)
    Stay tuned! :D
  4. Duality92
    Duality92 Member
    25 Feb 2015
    Prototyping some new cable combs :) Expect to see more 3D printing!
  5. Duality92
    Duality92 Member
    25 Feb 2015
    After much tinkering the best I can do with the 6600K is 4.7 GHz @ 1.488v load and 1565/8002 for the GTX 970 on Time Spy benchmark. As far as the 7870K goes, previously my best overclock was 4.5 GHz @ 1.5v with AMD Overdrive, but I can't wait to try it with BIOS overclocking.
    http://www.3dmark.com/3dm/15076547
  6. Duality92
    Duality92 Member
    25 Feb 2015
    UPDATE TIME! :D
    We finally finished the design of the case. My creative mind goes crazy when I get to do customization. Cutting should be starting today! :D This is an as-close-as-you'll-get render of the case :)
  7. Duality92
    Duality92 Member
    25 Feb 2015
    I'll just leave these here.
  8. Duality92
    Duality92 Member
    25 Feb 2015
    Just to let you all know, I should be getting pictures of the assembled case today :) To not reveal too much the paper backing will remain (it's actually to protect it during shipping, but helps to not reveal too much :p
  9. Duality92
    Duality92 Member
    25 Feb 2015
  10. Duality92
    Duality92 Member
    25 Feb 2015
    I can't tell you exactly what but I've got something big coming. Something Pascal big from Gigabyte.
  11. Duality92
    Duality92 Member
    25 Feb 2015
  12. Duality92
    Duality92 Member
    25 Feb 2015
    Rear panel and bottom motherboard mounting location preview :)
  13. Duality92
    Duality92 Member
    25 Feb 2015
    Preview of things to come!
  14. Duality92
    Duality92 Member
    25 Feb 2015
    So next week will be big. I'm getting my new video card (Thursday) and my case (Tuesday)!!
  15. Duality92
    Duality92 Member
    25 Feb 2015
    sooooooooooooooooooooooooooooooooooon...
  16. Duality92
    Duality92 Member
    25 Feb 2015
    Big thank you to ModMyMods for the sponsorship. Really is a pleasure working with the guys over there!
    I've updated the OP with the list of what they'll be sponsoring.
    • 2 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
    • Alphacool NexXxoS ST30 240mm
    • Alphacool NexXxoS XT45 280mm
    • Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M01
    • Alphacool VPP755 EisPumpe
    • Alphacool Eisdecke D5 Top - Plexi G1/4 - V.3
    • 4 * Alphacool G1/4 Passthrough Connector - Black
    • 4 * Alphacool Eiszapfen 3/8" ID x 5/8" OD Compression Fitting - Black 6-pack
    • 10 * Alphacool Eiszapfen 45° Angled Rotatable Adapter Fitting - Black
    • 10 * Alphacool Eiszapfen 90° Angled Rotatable Adapter Fitting - Black
    • 4 * Phobya LEDready Twin 5mm Ultra-bright white 30cm - Black
    • 20 feet of Mayhems 3/8"-5/8" (10/16mm) Ultra Clear Tubing
    • Mayhems X1 UV Blue Concentrate 250ML
  17. Duality92
    Duality92 Member
    25 Feb 2015
  18. Duality92
    Duality92 Member
    25 Feb 2015
    This update doesn't need many words.
  19. Duality92
    Duality92 Member
    25 Feb 2015
    Progress and planning is being made :) I'll try to make more this weekend and do some proper pictures. For now, I leave you with this.
  20. Duality92
    Duality92 Member
    25 Feb 2015
    Care package from ModMyMods! :D
