Scratch Build - In Progress ⭐ The First Double Sided ModArt QUADRAD Custom Case In The World.Update 23.03.2017
Discussion in 'Project Logs' started by arg-ist, 22 Dec 2016.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    ModArt ByLevon &arg-ist Collaboration
    The First Double Sided ModArt QUADRAD Custom Case In The World /
    With Four Loop ,Four Radiator,Four reservoir,Four Pump.
    Latest situation of the worklog
    My friend Levon offered to make a PC Case , that was a little different, big and extremly.
    He wanted to make a case with square Outlook(Quadrat)
    He wanted to make watercooled case with 4 loops by using 4 rads, 4 pumps ,and 4 reservoir.
    For this reason we gave to the case the name QUADRAD .
    Our aim was to use this box in the future with different systems
    We were going to do it from scratch, not by modifying a standard case.
    After some sketches, we decided to make a case like this , with design of Levon.
    The frame of the case is designed with a cross-section with 45 degrees broken corners.
    Main equipment will be as follows
    Mainboard: Z170A-XPOWER-GAMING-TITANIUM-EDITION
    https://www.msi.com/Motherboard/Z170A-XPOWER-GAMING-TITANIUM-EDITION.html
    MB monoblok
    EK-FB MSI Z170A XPower TE Monoblock
    RAM blok BİTSPOWER Universal RAM Module
    Video card : 2x MSI GTX1080 SEA HAWK EK X 8GB GDDR5X 256Bit DX12 Nvidia GeForce
    https://www.msi.com/Graphics-card/GeForce-GTX-1080-SEA-HAWK-EK-X.html#hero-overview
    PSU CORSAİR AX1500i,
    http://www.corsair.com/en/ax1500i-digital-atx-power-supply-1500-watt-fully-modular-psu-eu
    RAM
    Vengeance® LPX 64GB (4 x 16GB) DDR4 DRAM 3600MHz C18 Memory Kit - Black (CMK64GX4M4B3600C18)
    18 x HD120 RGB LED High Performance 120mm PWM Fan with Controller
    2 x CORSAIR Lighting Node PRO
    4 x Neutron Series™ XTi 960GB SATA 3 6Gb/s SSD
    the front and rear panels and side windows are planned as plain-flap on the plain wings , sides bent 45 degrees outward.
    So that 18 cm depth of the normal case , was removed to 30 cm.
    We started making a 1/1 carton model , to see what the case would be like in advance.
    There are air grids on the flaps and 4 reservoirs on the 4outsides.
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    When it came out as a case -sized volume, I started to draw vector drawings.
    As material came and went between aluminum and sheet metal (steel).
    For easy gas welding we used steel.
    2 M2 sheets required as material
    1.20mm thickness required for steel.
    and it weights 2X9.00=18.00 Kg
    If we have used aluminum sheet . we must use 2.5 -3.0 mm thickness.
    And it weights 13.5 -16.5 kg.
    when the gaps are dropped , steel case weihts 12.5 kg
    A reasonable weight of 12.5 kg when it is thought that a 900D case is 18.6 kg.
    During vector drawings, we decided to make the case not from 4 equal parts, 2 smaller equal parts to upper and lower, 2 larger equal parts to front and back.
    The case will consist of the 2 top and bottom parts and 2 front and back panels and 1 motherboard back plate.total 5 parts.
    Other than the integrated radgrils on the top a ,there are 4 holes 20 mm in diameter.
    To easy fill ofthe reservoirs with fluid.
    Panels providing cable connections to the case at the corners
    (B) At the top, an ON-OF button with 30 mm diameter and a 22 mm restart button and 2x USB 3.0
    (C) There are also two 5.25 for fan controllers close to the top.
    (D) At the lower part an HDD power on-of switch.
    (A)The front and back panels are equally made so that both sides of the case could be used as the front panel. Ther is no backside panel at this case.
    To check the size of the sockets, the cable panel was cut from plexi at laser .
    Necessary corrections done
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Prepared drawings were cut in CNC metal laser
    And bended with a CNC sheet metal bender.
    Bended parts
    All parts ,cut and bent ,together in bulk.
    Details inside and outside of the front and rear panels
    Details of the upper and lower panels
    If Porsche has a Show model ...
    This our Show model
    If she will enjoy the car
    I can enjoy too
  4. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    The parts were assembled for testing purposes.
    To prevent the shaking of the case , 2 bended steel pieces ( at Z shape ) added on the floor and ceiling.(marked)
    Then they were fixed to the base and ceiling with welder (punctured)
    And the MB backplate screwed . This has increased the stability much more.
  5. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    This looks very promising ,
    can´t wait to see where this is heading !!
    keep up the good work
  6. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Great work. I like the card board test.
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Very promising indeed!! Great stuff so far!
  8. Cheapskate
    13 May 2007
    Looking good! :D HUGE too. My guesstimation is about 2 foot square. (Maybe just a small cat? :lol:)
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Nice idea and execution so far. But dayum 80cm * 80cm is enormous!!!
  10. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks Cheapskate
    Of course it could be a smaler case .But;
    1- İt was his owner's choice. And it was enough for me with big case!!! 900D.
    2- We need a case for 4 loops with
    4x360 rad
    4x215 reservoir
    4X D5 pump
    And a classic for me, waterchanels from plexi
    Sorry ,what to do , everyone wants from me a big case …
    I promise you, I will build a supermini case… for you…
    Like this…:rolleyes:
  11. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks
    jojoharalds Supermodder
    Dr. Coin Supermodder
    Bartacus Supermodder
    arg-ist
  12. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    I/O panel 90 degrees rotated but not like at RAVEN 01 upwards ,
    just the opposite , I/O PANEL placed downwards and in the case.
    Not to open the side window every time , to connect cables to the MB , special extension cables used
    Used cables
    The sockets will be moved out of the case, into the corners,
    Cables assembled at corners
    The cables will be hidden behind the back panel through drilled holes.
    cable pas through holes
    Mounted sockets and cables
    The cables were taken from the holes to the rear
    To provide motherboard connectivity for these cables, the cable passthrough channels on the rear panel opened.
  13. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    With four bras case feet made on the lathe.
    Such a view was provided (without coating andwithout 4mm black delrin feet)
  14. Dr. Coin
    13 Sep 2013
    Reading though the list of cables you used and I noticed that the TOSlink is gold plated. What is the point of a gold plated optical connector?
    Case is looking good.
  15. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    At other cables are required to prevent oxidation.
    But I do not know how effective here at optical cable
    It can be also a marketing policy. arg-ist
  16. Dr. Coin
    13 Sep 2013
    Yay marketing :duh:
  17. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    İnstead of using a standart Modular I/O Panel like this..
    Metal rods were considered
    And they are made from brass on the lathe.
    The back of the CPU is emptied. With mounting of these bras rods in their place.
    The provisional trial board provided the following look
    There is free space for a counter nut (red marked )
  18. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Wow, very cool idea with the brass!
  19. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thank you Bartacus.
  20. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Another new one joined to us at this Project.
    My friend Levon became a baby.
    Nice to meet you baby…
    I will do next Project with you .
    Grand father- arg-ist
    The new cradle I bought for you
