Scratch Build - In Progress ⭐ The First Double Sided ModArt QUADRAD Custom Case In The World.Update 23.03.2017
Discussion in 'Project Logs' started by arg-ist, 22 Dec 2016.
  1. bakan
    bakan New Member
    19 Sep 2015
    Looking at your work.I want to see more.
  2. MellowMods
    MellowMods New Member
    17 Jan 2017
    Great stuff! Build looks incredible. Where did you get the 250V c14 plug?
  3. arg-ist
    arg-ist Member
    21 Dec 2013
    With temporary mounting of plexi water distributors, Cutting and mowing works are finished.
    Left distrubutor for MB +CPU+RAM Water blocks
    Right distrubutor for Water blocks of GRAPHİC CARDS
    Now all parts will go through. Parts must be grinded, sanded. The last check will be made and sent to powdercoatig.
    We chose RAL 7015 Slate grey
    Because we use powdercoating instead of RAL 7015 auto lacquer, we hesitate to grab this mat gray tone in color
    I undertook the construction of the case in this Project
    My work has come nearly to an end with the construction of water channels and painting.
    After that you can follow HERE what my friend levon can add to the case and do on this case.He must build Hardware,Watercoolingand cable management.
    THANKS TO ALL FOLLOWERS.
    To see you at a new worklog. arg-ist
  4. modartbylevon
    modartbylevon New Member
    21 Dec 2016
    Case is almost finished.We have prepared the water channels and leak tested. We are preparing case for the paint. It will be painted as soon as we finish our final touches :)
  5. calebkan
    calebkan New Member
    22 Mar 2017
    its really great work indeed..gz guys..and its really huge case..I'm following
    and
    I'm curious about the weight_?how much is the case?seems very heavy :)
  6. arg-ist
    arg-ist Member
    21 Dec 2013
    While waiting for the case from the paint, We did the leds of the water channels.
    There were channels for led around the plexi water ditributors
    LEDs buried in these channels
    Later, the LEDs checked.
    To prevent light leakage out of the LEDs, The LEDs were covered with black cold silicone on them.
    Ready for montage.
    Meanwhile, the braas parts came from nickel coating.
    Finally came the case from pulver coating.
    Nickel coated parts mounted
    USB sockets were long
    distances was made underneath from 8 mm plexi
    In this way, the USBs were fully inserted.
    Rear view of the case with mounting of the plexi water chanels
    Front view of the case
    Details
    Test lighting of water chanels without fluid . Rear view.
    Front view
    We made special parts from the braas to secure the covers.
    And we sent them to nickel coating
    Time to check the covers
    We mounted the back cover
    And then front cover
    Front cover detail view
    Front view of water channel
    My work has come nearly to an end with the construction of case and water channels and painting.
    After that you can follow what my friend levon can add to the case and do on this case.He must build Hardware,Watercooling and cable management.
  7. kim
    kim hardware addict
    10 Jan 2016
    I really love that case, I said it already, I even don't care of the quality of the pictures, because I enjoy following it so much, but I think such a art piece deserves a great quality final photo shoot...at least...
  8. Vault-Tec
    30 Aug 2015
    That thing is a monster :jawdrop:
    Love the reservoirs. Love how you've done a double glazing job and sealed the edges in black silicone.
    I bet that thing weighs a ton :thumb: :rock:
  9. Cheapskate
    13 May 2007
    Looking good.:thumb:
    I always had trouble with silicone. It's like, "It's been 2 months. I'm dry and you can trim me. -HA! HA! I tricked you! I'm not dry at all!"
  10. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    I'm in love with those water channels:rock:
  11. arg-ist
    arg-ist Member
    21 Dec 2013
    At beginning we thought , it would be huge or a hulk…
    But the flaps showed it smaller.It is not a huge…
    You can compare dimensions with equal cases at Photo.
    I have cutted up to 4 Corsair 900D cases until now. I think ı know 900D.
    Please try to use 4X250mm Reservoir + 4XD5 Pomp +4X360/60 Rads + 2X big Plexi water chanel
    İn a 900D….
    Mod Art Pc likes this.
  12. Mod Art Pc
    Mod Art Pc New Member
    22 Feb 2016
    I came. New images are ready soon ..
    Project is completed ..... :) :) :)
    HPC and AleksandarK like this.
  13. Mod Art Pc
    22 Feb 2016
  14. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    That 'stache though.
