Small Form Factor The Fit-PC
Discussion in 'Hardware' started by Langer, 21 Nov 2008.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    The Fit-PC
    Just stumbled across this and was curious if anyone has had a chance to play with one yet.
    Hardware
    CPU: AMD Geode LX800 500MHz
    Chipset: AMD CS5536
    Display: Integrated Geode LX display controller up to 1920x1440 !?!?!
    Memory: 256MB DDR 333MHz soldered on-board
    Hard disk: 2.5” IDE 60GB
    Ports
    2 x RJ45 Ethernet ports 100Mbps
    2 x USB 2.0 HiSpeed 480Mbps
    RJ11 RS-232
    VGA DB15
    The specs are nothing to write home about... in fact the router I'm using inside PrometheusCU has the same specs - and the 1920x1440 res specs have to be bloated (if not bloated, then simply useless).
    Has anyone seen this before? or have anything to say about it?
    I found it kind of interesting, I figured it would be good for a touch of music in the bedroom with the aid of a USB sound card.
    [edit]posted too soon, the price is $220US++ I think I'd opt for a Pico-ITX solution over this... with double the power[/edit]
  2. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Strange. The picture looks like it has a dipole wifi antenna out of the back, but the specs say nothing about it?
  3. Krikkit
    21 Jan 2003
    The specs say it has integrated G-wireless. It also says it has 512MB of DDR, dunno where Langer got his specs!
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    I copied my specs from their site, only I copied them from 'FitPC 1.0' spec, and not the 'FitPC slim' spec... by bad.
  5. Krikkit
    21 Jan 2003
    Fair enough really - they offer a Slim with 256MB of RAM too.
    Pretty cool though really. Definately a tempting idea for a Carpc.
