Scratch Build – In Progress The green water of class
Discussion in 'Project Logs' started by Corsaronero333, 25 Feb 2012.
  1. Corsaronero333
    Corsaronero333 New Member
    25 Feb 2012
    Hello I introduce myself my name is Ermanno I love modding and now I want to present my work.
    I hope you like it, the path will be 'long.
    It takes time ideas and furthering your friends crazy.
    The project is in most 'parts, the first will be' all the components in brushed stainless steel
    I apologize for my English but I'm 'using google translator
    Uploaded with ImageShack.us
  2. Corsaronero333
    25 Feb 2012
  3. Tonyevol
    Tonyevol New Member
    6 Jul 2011
    Hi Ermanno! Really nice to see your mod also there. Take the good flame of modding alive :)
    Cheerz!
    Tony
  4. Vandalo
    Vandalo Member
    24 Mar 2011
    Welcome Corsaro... OMG this should be a great job.
    For all... this guy is a great italian modder, I advise you to follow him.
    Good work Ermanno.
  5. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Thank you for taking the time to post here Corsaronero333 it must be frustrating having to use google translator!
    I have seen a few of your builds doing the web circuits and if they are anything to go by this should be awesome! :D
  6. asura
    asura jack of all trades
    22 Apr 2009
    That bares a passing (but much more elegant) resemblance to the HDD rack in the bottom of the Lian Li PC-A10. Hopefully the rest will continue to be sleeker and more intrinsically simple.
  7. Corsaronero333
    25 Feb 2012
    Thanks guys with all my heart, I guarantee you that the mod will be full of surprises ..
    Oh yes you are right for HD has been taken a design similar to the Lian-Li but eventually you'll see that change..
    Eheheheheh is beautiful ...... but the change is coming.
    First of all I have to remove the upper part of the support, because hides too much HD or SSD, so doing I take this opportunity to drill further supports aloggiare SSDs also in more 'I have to drill and countersink the bottom then I'll need' for anchor at the base, after threading from M3
  8. Corsaronero333
    25 Feb 2012
  9. Corsaronero333
    25 Feb 2012
    From here begins the frenzy to see how it comes out, and basically makes' her dirty figure, everything fits perfectly
    As last working, I just have to remove all sharp edges with a file, mount the rubber
    And after many adventures here we are with the supports of the SSD mounted
  10. stallo709
    stallo709 Member
    8 Apr 2011
    Hi corsaro, you are a great:clap:
  11. Tangster
    23 May 2009
    Looks good so far!
  12. Cheapskate
    13 May 2007
    :thumb: Looks good. I love stainless steel.
    Welcome to BitTech.
  13. Corsaronero333
    25 Feb 2012
    Thanks guys is a pleasure to be here in your company
  14. Corsaronero333
    25 Feb 2012
    And here is the second processing, brushed stainless steel.
    This keeps the same basic design as that of HD but change its width, the top will be slightly extended to cover the whole frame of a possible DVD.
    Before starting work, I have to drill through with a peak of 2.75 and then threading from M3 and countersink the screws where they will go to find accommodations.
    All parts including the base will be retouched with sandpaper to reduce the sign of the original glazing, considered excessive
    Assembling the various pieces
  15. One1ros
    One1ros New Member
    6 May 2011
    Great work! This is simply beautiful.
  16. A13X
    A13X New Member
    25 Feb 2012
    Very interesting and well done. Excellent solution. :hip:
  17. Corsaronero333
    25 Feb 2012
    thanks:rock:
    Tonight I continue not to leave you up with the processing and support for VGA slot for USB3 and the power button / reset
    Support for VGA
  18. asura
    22 Apr 2009
    Bench?
    Attention to detail is phenomenal.
  19. *Alex*
    *Alex* New Member
    23 Mar 2008
    wow man they look factory made real high class build going on here cant wait to see more!
  20. Corsaronero333
    25 Feb 2012
    :naughty:
    :thumb:
    Thanks guys, short new developments
