Scratch Build – Complete ⭐ The Ice Wall
Discussion in 'Project Logs' started by MPC, 1 Nov 2017.
  1. MPC
    MPC Member
    24 Oct 2015
    SSD supports with 2 mm thick aluminum sheet. Folding by hand.
  2. MPC
    MPC Member
    24 Oct 2015
    Plexiglas support, 8 mm thick, for top tank locking, temperature sensors and buttons display.
  3. MPC
    MPC Member
    24 Oct 2015
    Realization of the upper plate ducts and the expansion of the video cards.
  4. MPC
    MPC Member
    24 Oct 2015
    Box to cover the cables whit theme of the project. Hand bend plexiglass 4 mm thick with hot gun.
  5. MPC
    MPC Member
    24 Oct 2015
    Folding by hand wings motherboard tray that will allow the fastening on the sides of the radiators.
  6. Cheapskate
    13 May 2007
    Loving this, but Don't hammer stuff on the mill! Mill is your friend and buddy. :lol: Give the mill an apologetic oil massage.
  7. MPC
    MPC Member
    24 Oct 2015
    ahahahahah :hehe:
    The milling machine is pretty robust and giving light hammering on the work surface is like caressing it :grin:
    It is quite easy to bend aluminum sheets up to a thickness of 2 mm :thumb:
  8. MPC
    MPC Member
    24 Oct 2015
    Disassembling the radiators in order to make threaded holes on the sides, disconnecting the pumps inside the system because no. 3 D5 pumps will be used and then replacing the fans with the blue LED ones.
  9. MPC
    MPC Member
    24 Oct 2015
    Assembly of the entire base.
  10. MPC
    MPC Member
    24 Oct 2015
    Radiator insertion and visual test. Precision is everything!
  11. djlegend
    djlegend New Member
    9 Jun 2015
    Very good.
  12. MPC
    MPC Member
    24 Oct 2015
    Thank you very much :thumb:
  13. MPC
    MPC Member
    24 Oct 2015
    BrRrRr that coldddd
  14. dotafax
    dotafax New Member
    6 Feb 2017
    Good work, better final result of the initial project. Unfortunately I can not vote for it in the monthly contest.
  15. MPC
    MPC Member
    24 Oct 2015
    Thank you so much dotafax!
    Yes, during the course of work I wanted to change the back of the project to make it as much as possible on the Ice Wall. With the blue LEDs I get a cold shiver down my spine :grin:
  16. Gress
    Gress New Member
    10 Mar 2018
    Nice work witht he plexi structure, it's look great.
    I wanna see how this project turns in the end
  17. MPC
    MPC Member
    24 Oct 2015
    Thank you Gress :thumb:
  18. delevic
    delevic New Member
    21 Feb 2015
    Very interesting design.
  19. Cheapskate
    13 May 2007
    Ice wall
    OK, :duh: I finally get it. :lol: I'm so slow. Lovely job. Good call on changing the pumps. When I saw that cover plate off... What were they thinking?
  20. MPC
    MPC Member
    24 Oct 2015
    #BrRr I feel cold !
    This can be the hastag of the mod :grin::grin::grin:
    You are not slow, I'm who make the pitfalls :grin::grin::grin::grin::grin:
    My Mods are always particular and their name is always chosen with the main theme.
    I turned the radiators upside down and for this reason I disconnected the radiator's own pumps otherwise I would have burned them.
    The cover plate is normal plastic and instead of using the bolts they used self-tapping screws for the plastic.
    Soon a new sponsor for the ram and the ssd :rock::clap:
