The IDF Thread (Fall 06)
Discussion in 'Article Discussion' started by WilHarris, 25 Sep 2006.
  1. rupbert
    rupbert New Member
    28 Jul 2002
    Any idea what GPU was being used? Mika mentioned an nvidia chipset, I'm guessing quad SLI?
  2. samkiller42
    25 Apr 2006
    This aint fair, i was planning a Intel Based Mod, but i wont be starting for a few months. Bit-tech, tell intel to put this mod plan back a few months so i can start on mine :D
    Sam
  3. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    It's only for the design by the looks of it, so you don't need to have a working model as such.
    <A88>
  4. Lazarus Dark
    Lazarus Dark New Member
    14 Apr 2006
    wait, the million-dollar case has to be small? dam that puts me out.
  5. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Any links to an official page on the intel site or something, about the case design contest?
  6. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Linky
    Unfortunatly the competition isnt open to individuals :wallbash:
    Moriquendi
  7. <A88>
    10 Jan 2004
    Damn. Makes sense though, as very few of us are going to have the contacts or knowledge to get this thing mass produced.
    <A88>
  8. Moriquendi
    3 Nov 2005
    I suppose not, though i wonder if i could get away with saying i'm an oem because ive build computers for other people?
    Moriquendi
  9. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    :thumb: thanks for the link.
    Plus the money is for "co-marketing" and "hard tooling" only. Under those rules... meh
  10. Tyinsar
    26 Jul 2006
    Re: "Robson, the technology that will bring flash memory storage onto your motherboard."
    I understand that flash ram has a limit to how many times it can be flashed. I know that this limit it quite high. What I want to know is, how long this will last for the average user when used this way. (I'd hate to use it heavily only to have it die in two or three years)
  11. EQC
    EQC New Member
    23 Mar 2006
    On the other hand, even today I think a gigabyte of Flash RAM costs around $15-20 (I believe they've said that Vista is optimized for 1GB of this technology). As long as they were smart about how the Flash integrated with the motherboard (ie: some sort of standard card, and not some sort of chip that is both proprietary and varies from motherboard to motherboard), then replacing the flash every 2-3 years wouldn't be too much of a burden. In 2 or 3 years, a gigabyte will probably run you $2-3...and by then, with OS Service packs and what not, you might be wanting to upgrade to 2GB anyway.
  12. EQC
    EQC New Member
    23 Mar 2006
    Kentsfield
    This may be a dumb idea/question, as I don't understand the way a processor works as well as many others in the bit-tech forums, but:
    In a regular Core2duo, are the two cores able to communicate directly with each other?
    If they are, then I wonder if there is a way with Kentsfield to send threads that may want to share data/communicate with each other to a pair of cores that CAN communicate directly? For example, if I'm running some code that can only really run on 2 cores, then would that be confined to one of the core2duo's inside the kentsfield....or could it presumably send one thread to each of the core2duo cores and result in a slowdown? Would this be a matter of the OS knowing the difference between the 4 cores in the processor, or would it be some logic embedded within the Kentsfield package?
  13. Tyinsar
    26 Jul 2006
    true but the socket etc will add cost and probably won't be on many budget boards - who'll notice before the waranty is up? I like the idea and am hoping for a socket too.
  14. Tim S
    Tim S OG
    8 Nov 2001
    Core 2 Duo / Conroe has a shared L2 cache with a bus arbitration unit that allows the two cores to communicate with each other via the high speed L2 cache.
    With Preslersaurus (dual core via two Cedar Mill dies on one package), the cores communicated via the front side bus, meaning that there were situations where the front side bus was saturated. Kentsfield works in a similar way, in that there are two CPU dies on one package and they communicate via the northbridge/front side bus. However, unlike Presler, each of the dies has two cores.
    I am assuming that if you are running code that is optimised for two cores, it will run on one half of a Kentsfield CPU (i.e. one of the two Conroe dies). If you are communicating between the two Conroe dies, you will need to go via the front side bus. However, with the introduction of Advanced Smart Cache and Smart Memory Access technologies, Intel managed to make memory access and cache management more efficient on a dual core chip. This means that there is less traffic traveling across the front side bus and leaves more room for the two pairs of cores to talk to eachother.
    From my understanding, there are going to be very few applications where the front side bus is going to be saturated in the same way that it was with the Preslersaurus.
  15. bubsterboo
    bubsterboo New Member
    24 Jan 2006
    Ive always thought that having a gfx card in the form of a gpu socket (like cpu's) would be acool idea. Then you would only have to buy gpu's to upgrade.
  16. EQC
    EQC New Member
    23 Mar 2006
    Thanks for the answer Tim S :thumb:
    I'm still wondering how the RAM will work for the extra socket in either Intel's or AMD's ideas...as graphics ram is much faster than system ram (and just about the same magnitude in many systems). Will the extra socket have it's own RAM slots that'll take GDDR3 (or 4) somehow? Or is the more direct connection with the CPU going to pull in enough slack that the faster RAM isn't even necessary?
  17. Stwongbad
    Stwongbad New Member
    8 Jun 2006
    Lets hope the winner for the case design contest has somin better than BTX
  18. DLoney
    DLoney New Member
    21 Feb 2005
    So... could a home made system be entered into the contest?
    :confused:
    EDIT: NM, I now see we cant... :waah:
  19. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    So Intel is looking for a media pc thats stylish, small and able to work with any room of the house?
  20. DougEdey
    5 Jul 2005
    If the Wii can play videos over the network, we have our solution.
Tags: Add Tags
