Other The INTERWEBZ is dying.
Discussion in 'General' started by Jaybles, 26 Aug 2012.
  1. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    I cannot get onto these sites, an nslookup fails and I saw one person mention a problem with BTs DNS. Anyone heard anything?
    Thanks
    Teelzebub likes this.
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Nope, I've been trying to get on Kotaku for about ten hours now. I've not had any luck.
    This is even more concerning, it seems that BT really have screwed something up on their end.
    Edit; Mmm'kay. It appears to be BT's DNS servers, I just flipped my PC to use Google's DNS servers (8.8.8.8, 8.8.4.4) and suddenly I can load Kotaku without an issue. I hope they fix this quickly.
  3. KidMod-Southpaw
    28 Sep 2010
    I don't know if it's just these particular sites. I've been having DNS lookup failures all morning on TalkTalk!
  4. .//TuNdRa
    12 Feb 2011
    Give alternate DNS servers a try, be they OpenDNS, google, or some other source.
  5. KidMod-Southpaw
    28 Sep 2010
    Yeah, switched to the Google ones for now.
  6. Jaybles
    12 Feb 2011
    Yeah I'd done that.
    Edit: Trying to launch Crysis. This better not be related.
  7. .//TuNdRa
    12 Feb 2011
    Probably is. Might have to change the DNS on the router, if you have access. BT's seems to be a bit screwed up at the second.
  8. Harlequin
    Harlequin Modder
    4 Jun 2004
    not just BT - im with O2 and its down as well
  9. Jaybles
    12 Feb 2011
    I went for the try it til it works method. It worked.
    But now I cannot access Reddit -.- and this is with Google DNS.
  10. Teelzebub
    27 Nov 2009
    I had the same problem with Crysis this is the reply I got from steam to fix it
    Thank you for contacting Steam Support.
    If you are running in Windows Vista or Windows 7, please completely exit Steam, and right-click on the shortcut which you use to launch Steam and select "Run as Administrator."
    If you are running in Windows XP, take the following steps:
    1) Exit Steam.
    2) Go to the "Start" menu, select "Run", type "regedit" and click "OK".
    3) Navigate to the following registry key: HKEY_CURRENT_USER\SOFTWARE\VALVE
    4) Right click and select "Permissions"
    5) Check the "Allow" boxes for "Admin" and "System" for both "Full control" and "Read".
    The remaining steps apply to *all* versions of Windows.
    Then, verify the game's files at least once:
    Title: Verifying Game Cache Files (GCF)
    Link: http://support.steampowered.com/kb_article.php?ref=2037-QEUH-3335
    NOTE: There may be files that fail to validate. This is normal and can be ignored.
    If the issue persists, you may also need to manually run secondary installers required by this game.
    First, exit Steam entirely.
    Please download and install the latest DirectX update, available here:
    http://www.microsoft.com/downloads/...38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
    Also, please download and install the latest version of PhysX, available here:
    http://www.nvidia.com/object/physx_system_software.html
    Then, please install the latest Visual C++ run-time components, as described in the following article:
    http://support.microsoft.com/kb/259403
    If you have not already done so, please install the following .NET framework software packages:
    http://www.microsoft.com/downloads/...2F-5D1A-413D-8319-81DA479AB0D7&displaylang=en
    -and-
    http://www.microsoft.com/downloads/...51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
    You may also try the steps outlined in the "Games do not run after 'Preparing to Launch' FAQ:
    http://support.steampowered.com/kb_article.php?ref=6218-USFX-5568
    As well as the "This game is currently unavailable" FAQ:
    https://support.steampowered.com/kb_article.php?ref=4595-WEXN-6831
    If the issue persists and this game is not made by Valve, further support for this title is handled by a third party support department:
    https://support.steampowered.com/kb_cat.php?id=87 . Otherwise, please reply to this ticket if you still require assistance.
    Anytime you wish you can view your question online:
    https://support.steampowered.com/view.php?ticketref=2038-SDKZ-0475
    Jaybles likes this.
  11. .//TuNdRa
    12 Feb 2011
    More scarily; whatever this is just hit Google's DNS too. It's almost as if someone's managed to seed a set of dud links into every DNS I can get access to.
    Ironically; Open DNS's site is inaccessible.
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    Yep, I've been having DNS issues all morning on a variety of sites. I'm just going to wait for it to sort itself out.
  13. .//TuNdRa
    12 Feb 2011
    OpenDNS and Google's DNS servers just fell to the same issue Kotaku and LastFM became inaccessible.
    Fun times.
  14. sourdough
    sourdough Minimodder
    17 Sep 2010
    I am not sure if this is related, a lot of people are having issues connecting to major game servers.
  15. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    THE INTERNET IS DYING!
    On a more serious note, people have tried to attack DNS servers before. Anonymous were planning to do it, but it was called off, after realising just how stupid it was.
  16. .//TuNdRa
    12 Feb 2011
    Then why would we loose access to such a seemingly random assortment of sites? I mean, who gains from breaking Kotaku and LastFM access?
    Besides, how would you even go about corrupting so many DNS tables?
  17. Jaybles
    12 Feb 2011
    AND REDDIT!
    and ebay.
  18. KidMod-Southpaw
    28 Sep 2010
    The interwebs REALLY IS dying!
    *Please change thread title accordingly.
  19. .//TuNdRa
    12 Feb 2011
    Ebay still works on this end... As does Reddit, but i'm still using OpenDNS at the moment. It's possible they'll vanish too.
  20. Jaybles
    12 Feb 2011
    Done.
    This will be something to tell the grandchildren. "I was there when the internet died."
    And in case we lose Bit.
