Scratch Build - In Progress ⭐ The Iron Turnip--2-2019-creeping forward like a snail into the hot sun
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Cheapskate
    13 May 2007
    I vaguely remember there's an A10 in it. :lol: I'm not here for the hardware parades.
  2. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    It's in your sponsors sig...
  3. Cheapskate
    13 May 2007
    Is it? :lol:
    The_Crapman likes this.
  4. Cheapskate
    13 May 2007
    Don't die of shock. I have a 2nd update for the month. It's kinda handy when the temperature drops below the working temperature of pvc glue. I got time off thanks to a broken water main on the current vacancy and a cold snap.
    -Have a commemorative photo celebrating the half-cleaning of the garage workbench. I know. It amazed me too.
    -I was also filing on that bit of lawnmower engine block. I cut a tab for one end, and drilled screw holes in the other.
    -Now I just need a hole. I added some plexi rod to the top of the fanguard where there was a gap.
    -Perfect! Now I can just slide the guts in, and plug in the case components.
    -Holy cow! look at all that wasted space.
    -Oh, dear... That's some nasty pressure cracking. Maybe 4 O-rings was too many. It's only stressed on the decorative layer, though.
    -I still had some liquid nail, so I used that for the access panel mount. The delays haven't been because of a lack of free glue. -No, really! :worried:
    -I can shape the finned part now. I dug the bench sander out and flattened the sawed bits.
    -I filed out the bolt areas and other stuff that filled the fins in.
    -Epoxying this was tricky. To keep it in place I masked off the front, applied the epoxy, and while holding it in place hot glued the front. After that cooled I could let go and let it set overnight.
    -What's next? I dunno. here's half of an old frying pan though.
    Thanks again to my sponsors:
    Hey! It is in the sponsor pics! :lol:
    Goatee likes this.
  5. Cheapskate
    13 May 2007
    Oh, and here's one excuse for not getting much done last year.
    HYPE!
    Vault-Tec and perplekks45 like this.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    An excuse. But an acceptable excuse. :thumb:
  7. _Prometheus_
    _Prometheus_ Active Member
    2 Jul 2017
    You are the maddest modder! I am your admirer. :dremel:
  8. Dr. Coin
    13 Sep 2013
    The almighty frying pan, now this mod is getting exciting.
  9. Cheapskate
    13 May 2007
  10. perplekks45
    9 May 2004
    You're the man with a plan for the pan. Is that what you're saying, mate?
  11. Dr. Coin
    13 Sep 2013
    No he's say he's the man with pans. Plans do not factor into this.
  12. Vault-Tec
    30 Aug 2015
    Total panhandle.
  13. Cheapskate
    13 May 2007
    Ooof. punning. :p
    The plan is to destroy their ability to be used as junk containers. This household has a horrible tendency to fill any object that can hold stuff.
    -Of course, there's other problems too. We inherited two NEW vacuum cleaners this month, bringing the total up to 9, (that I know of. :worried:)
